Help with fast idle!
Discussion in 'Cherokee' started by Dax42, Dec 8, 2019.
  1. Dec 8, 2019 at 2:08 PM
    Dax42
    Dax42 [OP] New Member
    Dax
    01 Cherokee Sport
    Hey! Just put it all back together after replacing the head gasket. Was very happy to hear her turn over and purr to life. Then the engine started racing as if I had the accelerator on the floor. I shut off the engine when it hit about 3k rpm. I never touched the gas.
    started it a few more times with the same result. Checked throttle linkage and they seem fine. What am I missing?
  2. Dec 8, 2019 at 3:45 PM
    Welcome to the forum @Dax42 . That Was going to be my suggestion. Since you removed the linkage and all concerning the top of the motor. Gotta be something there. Replacing head gasket it self. Would not cause a racing motor.
    Double check throttle linkage and all concerning the throttle.
    Post up if you find the cause.
  3. Dec 8, 2019 at 4:53 PM
    Your intake manifold is not fully seated, 100%. Very common occurrence when doing a head gasket.
    JKBob 25, aggrex and LYFZGOOD like this.
  4. Dec 8, 2019 at 8:33 PM
    Air...vacccum leak....Awesome heads up @Prerunner1982 . Didn't cross my mind. Blame it on work load and Holiday Season.....:(
    Billy1234 likes this.
  5. Dec 9, 2019 at 3:23 AM
    Dax42
    Dax
    01 Cherokee Sport
    Thanks guys. Will check for vacuum leaks and properly seated intake manifold this weekend. Will let you know what I find.
