Dies while making left turns
Discussion in 'Wrangler YJ (1986-1995)' started by Motovated1, Aug 16, 2019.
  1. Aug 16, 2019 at 9:21 AM
    Motovated1
    Motovated1 [OP] New Member
    1992 wrangler , 4.0 , manual trans
    4 inch lift , tires and wheels , winch .
    So driving home when making a left turn Jeep dies , starts after a min or so no problems the rest of the way home , next day went to work no problem but going home died same spot , I did stop for fuel just before it stopped second time , day three went home different way died on sweeping left . looked for short bad connection , fuel pump replaced last winter and coil summer before . This did all start after over heating not sure if its related . Thinking crank sensor ???
    Any ideas anyone???
  2. Aug 16, 2019 at 4:18 PM
    The '92 4.0 engine should have a crank sensor in the top left side of the bell housing. There is also a cam sensor located under the distributor top plate, if that goes bad it will produce similar results. These sensors do go bad and when they do the issue gets eventually worse to the point that the engine will not start at all. Although you could have fuel pump issues, a pressure test should provide an indicator.
    Bob, JKBob 25 and aggrex like this.
  3. Aug 16, 2019 at 8:12 PM
    Welcome to the forum @Motovated1 . I believe @Jim Beam has got you heading in the right direction.
  4. Oct 15, 2019 at 11:27 PM
    Ghostjeep89
    Ghostjeep89 New Member
    Gil
    Yj89
    Happens to mine only when I'm low on gas. The gauge on mine is slightly off.
