Hot air being blown in cabin
Discussion in 'Wrangler YJ (1986-1995)' started by Red93yj, May 23, 2020.
  1. May 23, 2020 at 5:20 AM
    Red93yj
    Red93yj [OP] Member
    Hello all,
    I’ve noticed that hot air will blow into the cabin after some time of driving. I suspect it’s from the engine and is coming from a vent back under the radio area I can feel it blowing when I drive. Any thoughts on where it’s coming from and how to stop it?
    thank you
  2. May 23, 2020 at 4:14 PM
    I would first suggest spending some time under the dash and verify that it is coming from a vent. If so, check for a cable that controls it and why you cannot close it.
  3. May 23, 2020 at 5:39 PM
    Red93yj
    Red93yj [OP] Member
    If I show you a picture, could you give me your advice as to where to look?
  4. May 23, 2020 at 9:12 PM
    It probably wouldn't hurt, that will give others a chance to look also.
  5. May 29, 2020 at 11:01 AM
    Red93yj
    Red93yj [OP] Member
    This is the vent
  6. May 29, 2020 at 8:31 PM
    If that box is missing a cable operated door a thrifty fix would be to close it for the summer or go to the local car parts lot and find a similar unit.
  7. May 30, 2020 at 7:58 AM
    Isn’t the door inside the box?? I can’t tell.
  8. Jun 4, 2020 at 6:27 AM
    TJ4me
    TJ4me Active Member
    2001 Jeep Wrangler Sahara
    The position of the cable does not make sense...A push or pull of the cable does not look like it will not move the damper shaft or damper. Check the movement of the damper assembly and make sure it moves freely and actually moves the damper open and closed...
  9. Jun 4, 2020 at 7:29 AM
    Look at the the part the cable goes through the right side is squeezed tight the left side is not there for letting the cables slide freely and not opening and closing the door is what I think :fingerscrossed:
  10. Jun 4, 2020 at 9:36 AM
    Do any other positions of the hvac system work?
