How do I know if I have trac-loc or not ?
Discussion in 'Wrangler TJ (1996-2006)' started by hutchtoy, Aug 21, 2017.
  1. Aug 21, 2017 at 8:19 PM
    hutchtoy
    hutchtoy [OP] New Member
    04 unlimited
    raised body and suspension, larger tires
    Just got a 04 TJ unlimited and am changing all the fluids so I know when it was done last and look at the diff gears to make sure they are ok. Added Mobil 1, 70 w - 140 but how do I know if I have Trac -Loc or not? The rear didn’t look like a possi set up but was beefier than the front. Tags on the rear dif show - 52114210AA T-L (traction lock?) and 80w90 60 oz + FM4 oz (quantity with additive ?). Front tag had 52099200 AE, 3 78 611312-4.
  2. Aug 21, 2017 at 8:32 PM
    The way I have done this, is jack up the axel, with both tires off the ground, and spin one by hand. If the other side spins the same way, you have a No-Slip, or Trac-Lok. If it spins opposite, then its an open diff.
  3. Aug 21, 2017 at 9:19 PM
    Welcome! In addition to Chris comments, with the axle cover off the assemblies look different
  4. Aug 22, 2017 at 6:27 PM
    Welcome to the forum hutchtoy.
