How much can my 2011 JK tow?
Discussion in 'Wrangler JK (2007-2017)' started by Newjkowner, Mar 10, 2017.
  1. Mar 10, 2017 at 12:23 PM
    Newjkowner
    Newjkowner [OP] New Member
    Steve
    Texas
    2011 jk
    Soft top, winch bumper and winch, cold air intake, mesh top, DVD Bluetooth receiver, back up camera, remote start and grab handles. Wheels and tires.
    I recently purchased a used 2011 JK and I want to tow a travel trailer but I'm not sure of the towing capacity. How can I find out how much I can tow?
  2. Mar 10, 2017 at 12:43 PM
  3. Mar 17, 2017 at 12:23 PM
    SmileyOR
    SmileyOR New Member
    Researching
    Within the limits of the 2,000 pounds you should also consider if you are towing on level ground mostly or if you are constantly pulling up and over mountians to get to where you are going. A lighter trailer that has what you need might be advisable over a heavier with all the bells and whistles trailer.
  4. Mar 21, 2017 at 9:19 PM
    The towing limits for my 2016 JK 3.6L 6 spd were bumped up 350/3500 but realistically neither the stock JK/JKU are best for heavy towing or tongue weight. IMO with the 2011 JK 3.8L stick with 200/2000 or less and keep the frontal area square footage of your trailer limited to 25 sq ft.
