I put a 4.0 from an 87 Cherokee Laredo into a 95 Cherokee Sport
Discussion in 'Cherokee' started by David96cherokee, Mar 4, 2021.
  1. Mar 4, 2021 at 11:45 AM
    David96cherokee
    David96cherokee [OP] New Member
    David
    1995 white cherokee sport
    swap engine
    I put a running 4.0 out of a 87 cherokee laredo into a 95 cherokee sport , only changing intake manifold. will not run at all now. Any help on what else I should have changed ? everything looked the same except for the intake . should I have changed the flywheel for the crank sensor . Cant figure out Help
  2. Mar 4, 2021 at 6:34 PM
    There's like a 100 issues that could result in an engine swap. Especially when there's a 8 year difference in Jeeps and motors. Computer, sensors, etc.
    BTW...welcome to the forum....
    Justanotherjeeper and aggrex like this.
  3. Mar 12, 2021 at 2:09 PM
    My first thought before I finished reading your post was the flywheel. As long as you re-used all the 95 plugs and one isn't missing the flywheel is all that I can think of mainly because they use different engine management systems.
  4. Mar 23, 2021 at 5:07 AM
    pyrotech
    pyrotech Member
    To make the swap smooth All the sensors and external accessories from the original vehicle transfer over to the donor in this case.
    I did 5he opposite 97 4.0 into my 92 long as I kept all the obdi stuff I had zero issues
    JKBob 25 and Justanotherjeeper like this.
