Identifying this axle
Discussion in 'General Jeep Discussion' started by red, Apr 28, 2019.
  1. Apr 28, 2019 at 7:10 PM
    red
    red [OP] New Member
    I am trying to identify the axle in the pictures. I was told it came from a 2 wheel drive mail jeep. I am trying to see if Wilwood offers a disc brake conversion to fit it but need to know what jeep came from.
  2. Apr 28, 2019 at 7:25 PM
    Yeah....ummm. Welcome to the forum @red.
    https://www.wilwood.com/
    Thought this might be a good place to start. Sorry....most members probably have not come across this.
  3. Apr 28, 2019 at 7:43 PM
    DustStorm4x4
    DustStorm4x4 Well-Known Member
    04 LJ
    Front or rear axle? DJ5s came with a Model 20 axle in the rear. Not sure what they had in the front.
    [​IMG]Properly identifying a Model 20 is pretty simple. Take a look at the pumpkin (the centersection of the axlehousing) and examine the diff cover. A Model 20 has a rounded cover with no drain plug, kind of like a ball that has been cut in half. Also, the cover attaches to the axlehousing with 12 bolts.
  4. Apr 28, 2019 at 11:33 PM
    DustStorm4x4
    04 LJ
  5. Apr 29, 2019 at 7:25 AM
    Welcome to the site!
  6. May 1, 2019 at 3:35 PM
    Oh and also they weren't very strong lol I wanna say the Willy's panel wagon had same axle
  7. May 1, 2019 at 6:49 PM
    The AMC 20 is a great axle with 2 weak links. The first is 2 piece axle shafts. Replace them with chromo 1 piece shafts. G2 shafts are $200+/-. 2. The axle tubes are pressed into the pumpkin. They need to be spot welded to prevent them from spinning out under load. The ring gear of the AMC 20 is bigger than the Dana44 ring gear making it a stronger axle set up . Yes in stock form it is weak, but it can be made really strong.
  8. May 1, 2019 at 6:57 PM
    I knew someone would know better than me ty @OFFGRID
    OFFGRID likes this.
  9. May 1, 2019 at 7:10 PM
    We kinda strayed here guys. He was asking bout what jeep its off of. And if theres a brake conversion kit for the axle. So unlike us......to stray.... :p
    TJ_abuser likes this.
  10. May 1, 2019 at 8:01 PM
    red
    red [OP] New Member
    Thanks guy's. It is an axle in a sand drag jeep I just acquired. It does not have brakes on the front axle and I would like to add them but Wilwood needs to know the axle model to see if they have a set of brakes for it.
  11. May 2, 2019 at 5:53 PM
    I have done a little research to figure out what might be compatible with your front end. The old Mail Jeeps (DJ5) run the same drum brakes found on the 1975 CJ5. The 75 CJ5 runs a Dana30 up front. Quadratec makes a Disc brake conversion for the 75 CJ5, but I cannot confirm that it will work on your axle. I would think so, but I don't know if any mods were made to your axle for your setup. A call to quadratec might help. Here are 2 links you might be interested in:
    https://www.quadratec.com/products/22700_08.htm
    https://www.morris4x4center.com/sus...ke-systems/jeep_cj5--brake_conversion_kit.htm
  12. May 2, 2019 at 5:59 PM
    I'm thinking its a Dana 25.
  13. May 2, 2019 at 9:40 PM
    Possibly, but the Dana 25 is a ball and socket kingpin like steering knuckle. It is really neither. It should be a solid bar across where the pumpkin would have been because it it 2 wheel drive. Just trying to figure out what parts will fit on it. Here is a Dana 25:
  14. May 2, 2019 at 9:41 PM
    Old Toyota have that same ball and socket on the front end
