Installed a new starter, now there's a gap
Discussion in 'Wrangler TJ (1996-2006)' started by Qwuark, Dec 27, 2019.
  1. Dec 27, 2019 at 8:13 PM
    Qwuark
    Qwuark [OP] Member
    02 TJ
    1.5" spacers
    Thanks to the help I got a few weeks ago, I found the correct starter and got it installed.
    Now, though, there is a small gap. I'm not sure if this is an issue or will cause problems.
    Thoughts?
  2. Dec 27, 2019 at 9:47 PM
    Any issues starting the TJ with the new starter? Perhaps some high-temp RTV might suffice to keep dirt and water out of the large gap. Its not generally a water proof starter mount but neither is it typical to have a large open gap either. If you purchased the starter locally, see if they have a replacement starter with a mounting base that better matches the old starter.
    chris4x4 and Qwuark[OP] like this.
  3. Dec 28, 2019 at 10:18 AM
    Qwuark
    Qwuark [OP] Member
    02 TJ
    1.5" spacers
    This was the only starter I found locally. It started right up.
    I think I also have an issue with the clutch safety switch, which I'm going to attempt to bypass.
    Maybe Peratex to seal it?
  4. Dec 28, 2019 at 10:46 AM
    Well if it's starting the jeep well I'd keep the starter. It gets hot in the motor-to-starter area so make sure whatever you use can handle the temps. Perhaps make a small metal trim plate to cover the gap and use the closest starter bolt to hold the plate.
    chris4x4 and Qwuark[QUOTED][OP] like this.
  5. Dec 28, 2019 at 12:28 PM
    Qwuark
    Qwuark [OP] Member
    02 TJ
    1.5" spacers
    Thanks for the ideas!
