INSTRUMENT CLUSTER ICONS STAYING ON
Discussion in 'Cherokee' started by MARLIN60, Jan 16, 2018.
  1. Jan 16, 2018 at 1:48 PM
    MARLIN60
    MARLIN60 [OP] Active Member
    Hey guys. I have an annoying, and what i believe to be, minor prob. A few days ago, my battery, on my '06 Cherokee discharged completely. After recharging, i started it up, and 4 of the cluster icons stayed on. Thought if i just drove X amount of miles, they would reset to off, but they stayed on. Took off positive batt cable, for about 10 mins., hoping that would do it, but again, no good. The 4 icons are: #6-Air Bag, #9-Security Light, #11/16-ESP/BAS light. Any help, or suggestions?
  2. Jan 16, 2018 at 4:38 PM
    Only thing I can think of, is to check fuses.
  3. Jan 16, 2018 at 6:50 PM
    As Chris4x4 said. Also my thought. Not sure your Cherokee is like my 16 JK. But to clear lights. Turn on ignition, but don't start. And depress gas pedal 3 times within XX seconds. ????. :notsure:. Maybe....
  4. Jan 16, 2018 at 7:50 PM
    MARLIN60
    Thanks guys, i'll give both suggestions a try :fingerscrossed:
  5. Jan 16, 2018 at 7:57 PM
    Hope we helped. :). Let us know....ok...give us a chance to try again....Lolll.
  6. Jan 17, 2018 at 8:46 AM
    MARLIN60
    Will do JK :)
  7. Jan 17, 2018 at 3:57 PM
    MARLIN60
    Well, i tried your suggestion JK, and no luck. Tried it a few times, and even tried a few more brake pumps too, but that didn't work either. Didn't try the fuse suggestion Chris, as it is damn bitter cold here. It's supposed to get back to the normal January temps, in a few days, so maybe i'll get a chance to check the fuse suggestion out :frusty:
  8. Jan 17, 2018 at 4:00 PM
    I know you disconnected the battery but you might try disconnecting both cables and touching them together to clear the computer.
    OFFGRID likes this.
  9. Jan 17, 2018 at 4:10 PM
    MARLIN60
    I'm certainly not an automotive ace Prerunner, but that doesn't sound good. You sure that wouldn't do some major electronic damage?
  10. Jan 17, 2018 at 4:16 PM
    Have had to do it on multiple JK Wranglers and it is a fairly common practice to clear Check engine codes.
    The computer will have to relearn a few things but it's not a big deal.
    But I understand your concern after all it is your vehicle.
    OFFGRID likes this.
  11. Jan 17, 2018 at 4:22 PM
    MARLIN60
    Just re-read your post Prerunner, and at first i thought it meant sending power through cables, but touching them together, while OFF the batt terminals wouldn't. Thanks for the tip. Will try that tomorrow :bowdown:
  12. Jan 17, 2018 at 5:04 PM
    MARLIN60
    Is there a minimum length of time the cables should be connected to each other Prerunner?
  13. Jan 18, 2018 at 5:34 AM
    I usually just hold them there for about 5 seconds.
    OFFGRID likes this.
  14. Jan 18, 2018 at 8:26 AM
    MARLIN60
    Ok, will post back with results.
  15. Jan 19, 2018 at 12:47 PM
    MARLIN60
    Well guys, apparently the aggravating prob, isn't so minor after all. I tried connecting pos/neg cables together for 1/2 hr, and had same icons on, after i started it. Knowing i wasn't going to be using it today, i re-connected cables together again, and left it like that over night. Same results, so for some reason, data hasn't been erased???? Is it possible i have to drive it X amount of miles, before they clear?
  16. Jan 19, 2018 at 1:23 PM
    When running were there any check engine lights? These may have been cleared when the battery got disconnected. Rent borrow a code reader to check for any codes that may clue us any issues.
  17. Jan 19, 2018 at 1:29 PM
    MARLIN60
    No, there was no check engine light, and i have a OBD 11 code reader. It shows no codes, and just in case, i entered erase?
  18. Jan 19, 2018 at 4:59 PM
    Might want to look at the fuses as mentioned earlier and consider getting the alternator/charging system checked out
  19. Jan 19, 2018 at 5:32 PM
    MARLIN60
    Am planing on checking on checking fuses tomorrow Aggrex, but as any one who owns one of these beasts, you have to be a contortionist to get at them :) Could you explain why a discharged battery (my doing), would give me/you reason to check alternator/charging system?
  20. Jan 19, 2018 at 5:43 PM
    Unless you know what discharged the battery (i.e. lights left on, age, etc), it's something ez to test to eliminate a variable
