Intermediate shaft won't come out
Discussion in 'Wrangler YJ (1986-1995)' started by Hudsamlare, Sep 14, 2018.
  1. Sep 14, 2018 at 10:26 AM
    Hudsamlare
    Hudsamlare [OP] New Member
    1988 wrangler
    Why is intermediate shaft stuck?
  2. Sep 14, 2018 at 10:32 AM
    Welcome to Jeeps.net.
    I have never dealt with the intermediate steering shaft so I don't have any tips or tricks.
    Hopefully someone will pop in with some help for you.
  3. Sep 14, 2018 at 12:00 PM
    Welcome aboard!
  4. Sep 14, 2018 at 1:22 PM
    Hudsamlare
    1988 wrangler
    Its the intermediate axle shaft. I got the outside ones out, but the intermediate one is stuck for some reason.
  5. Sep 14, 2018 at 1:42 PM
    I must have missed your Jeep info earlier, my apologies.
    Passenger side front axle shaft? I am not all that familiar with the early Dana 30 axles but it has a Central Axle Disconnect that you may have to remove from the axle tube in order to remove the shaft. It contains a shift fork that slides a collar to connect the two piece shaft. Other than that I can't think of anything that would be holding the axle in.
  6. Sep 14, 2018 at 5:23 PM
    If you haven't already done so you have to remove this cap and shift fork off of the rear of the front axle in order for the passenger side inner axle to be removed.
