Intermittent gas starvation
Discussion in 'Grand Cherokee' started by 1eyemac, Jun 16, 2020.
  1. Jun 16, 2020 at 5:00 PM
    1eyemac
    1eyemac [OP] New Member
    Mickey
    2002 Grand Cherokee
    Have a 2002 Grand Cherokee 8cyl.
    Problem: dies sometimes while driving. Sometimes it will start again and sometimes I have to let it just sit (minutes, hours, days).
    Repair: I replaced fuel filter. It started right away, then it died after 2-3 minutes. It started again, drove it around neighborhood no problems. Parked it, wouldn't start later.
    What could problem be? Fuel pump? Something else?
    Thanks for any help.
  2. Jun 16, 2020 at 6:36 PM
    Check fuel pressure for starters.
  3. Jun 16, 2020 at 7:12 PM
    1eyemac
    Mickey
    2002 Grand Cherokee
    So if there's a pressure problem what would that indicate?
  4. Jun 16, 2020 at 9:00 PM
    Lack of fuel pressure usually indicates a problem with the fuel pump
  5. Jun 16, 2020 at 10:31 PM
    1eyemac
    Mickey
    2002 Grand Cherokee
    I'll check pressure and check out pump. Thanks
  6. Jun 17, 2020 at 2:46 PM
    An erratic pressure reading will be for sure a bad pump, have fun changing it.
  7. Jun 17, 2020 at 4:22 PM
    What’s the big deal? is it in the tank??
  8. Jun 19, 2020 at 4:10 PM
    Toshs69
    Toshs69 New Member
    Tish
    2004 Grand Cherokee Loredo
    Check your sensors. When your Crankshaft sensor goes out it feels like you’re losing power actually you do lose power like your fuel is plugged. Then when it cools down it starts up and drives a little bit until it happens again
  9. Jun 19, 2020 at 4:58 PM
    A 2002 GC just might send out a code indicating such an issue. I had a 96 grand that had a cps go bad and it never sent a code.
