Issue with Titan 4.7L stroker in 94 Wrangler
Discussion in 'Wrangler YJ (1986-1995)' started by Scottbonner1970, Sep 5, 2017.
  1. Sep 5, 2017 at 11:03 AM
    Scottbonner1970
    Scottbonner1970 [OP] New Member
    1994 Wrangler yj
    I recently replaced the stock 4.0 with a 4.7 stroker. I also replaced the injectors with 24 lb injectors. It will crank and idle but when I push the gas it runs raggedly. The motor is a crate from Titan. I need help!!!!!
  2. Sep 5, 2017 at 12:13 PM
    Welcome to the site! Have you talked with Titan to see what solutions they may have?
  3. Sep 5, 2017 at 6:40 PM
    Welcome to the forum. It's a crate motor and it'd not running under throttle. I'm subbed. Definitely keep us posted. I'm sure it will work out for ya.
  4. Sep 6, 2017 at 8:59 PM
    SmittyJeeper
    06 wrangler 4.0 6speed
    Sounds like you distributor is a tooth off
  5. Sep 13, 2017 at 6:35 PM
    Raggedly can mean many things. Cam sensor, crank sensor, too much fuel, not enough fuel, disconnected or damaged vacuume line especially to the distributor. Timing not set correctly. I like Chris's idea and call Titan. They have a responsibility to help you.
  6. Sep 13, 2017 at 7:49 PM
    UrbanCowboy
    UrbanCowboy Well-Known Member
    Sean
    Scottsdale AZ
    2002 Wrangler... Hulk
    I hope you are able to get this sorted out. I'd love to hear how the power is as I eventually want to do a stroker on my TJ.
