JDMCQ's Garage
Discussion in 'Wrangler JL Builds (2018+)' started by JDMcQ, Mar 23, 2018.
  1. May 8, 2018 at 11:48 AM
    #61
    Stuff the area with spray in foam to control that warbling rumbling background noise.
    JKBob 25, chris4x4 and OFFGRID like this.
  2. May 8, 2018 at 11:49 AM
    #62
    JDMcQ
    JDMcQ [OP] Well-Known Member
    John
    2018 JLUR
    Spoke with Customer Care and opened a case. They are contacting the dealership now.
  3. May 8, 2018 at 11:56 AM
    #63
    You won't be able to tell the difference between it and all the dried mud and rocks collected from the off-roading trips.
  4. May 8, 2018 at 7:33 PM
    #64
    JDMcQ
    John
    2018 JLUR
    Received a voicemail from Jeep Customer care. They claim that because I was installing "aftermarket" parts the warranty would not cover my issue. Funny how I never mentioned the brand of the items I was installing. I also don't see what I was installing has to do with a manufacturers defect.
    The Jeep has been sent to a body shop for an estimate. Once received, Jeep will decide their next step, if any.
  5. May 9, 2018 at 5:29 PM
    #65
    JDMcQ
    John
    2018 JLUR
    Is this what commutes look like when you own a Jeep?
    Still no word on mine.
  6. May 9, 2018 at 9:09 PM
    #66
    DustStorm4x4
    DustStorm4x4 Well-Known Member
    04 LJ
    How much mpg you gettin? Just kidding, but I like the new Chevroleggs model you got as a loaner.
  7. May 10, 2018 at 5:14 AM
    #67
    Not to add to your issue(s) but a U43 recall was just announced that you should check out while its at the dealer
    DustStorm4x4 and chris4x4 like this.
  8. May 10, 2018 at 5:21 AM
    #68
    JDMcQ
    John
    2018 JLUR
    Thanks for the heads up. Unless they do it on their own, I'll take it to a better dealership for that.
  9. May 15, 2018 at 7:06 AM
    #69
    JDMcQ
    John
    2018 JLUR
    I got my Jeep back!
    Attached is a picture of the work order. They called the repair a "One time goodwill repair". Generous considering that the issue was caused by a factory defect. They also said that Mopar side steps do not require body bolt removal. Steps, no, but the Mopar premium rock sliders (not the rails), I believe, do.
    Regardless, the Jeep is back with me. None the worse for wear. The sliders go back on this weekend.
  10. May 15, 2018 at 10:35 AM
    #70
    You should go buy a lottery ticket.
    JKBob 25, Rc Jeep and chris4x4 like this.
  11. May 15, 2018 at 5:43 PM
    #71
    JDMcQ
    John
    2018 JLUR
    I bought one the other day. Didn't win anything.
  12. May 15, 2018 at 7:52 PM
    #72
    Try again dude. Things happen in 3s. Try again.......twice...lolll.
    Least it all worked out with your JKU. Jeep jeep.
  13. May 16, 2018 at 7:00 AM
    #73
    2 bucks for a bolt...….ouch
  14. Jul 3, 2018 at 8:00 AM
    #74
    csuviper
    csuviper Tundra Guy Moderator
    Brian
    Colorado
    18 Jeep Wrangler JL Rubicon
    Will be mostly stock
    :spy:
  15. Jul 3, 2018 at 9:33 AM
    #75
    Welcome to.......wait....what's happening
  16. Jul 3, 2018 at 5:12 PM
    #76
    JDMcQ
    John
    2018 JLUR
    :confused:
  17. Aug 3, 2018 at 8:27 AM
    #77
    csuviper
    Brian
    Colorado
    How are you liking the JCR sliders?
    Would they a good step for a 6yo into the back seat?
    I know you had the bolt problem but that was not an issue with the steps.
  18. Aug 3, 2018 at 8:31 AM
    #78
    JDMcQ
    John
    2018 JLUR
    The sliders are great. They would work well as steps. I stand on mine to wash the roof so a 6yo should find them helpful. I have mine wrinkle powder coated so they have a little bit of grip to them.
