Jeep cutting off
Discussion in 'Cherokee' started by 96 cherokee country, Nov 3, 2018.
  1. Nov 3, 2018 at 8:50 AM
    96 cherokee country
    96 cherokee country [OP] New Member
    John
    1996 Jeep Cherokee Country 4.0
    Jeep cranks and idles fine. Put it in drive and and take off and then radomly dies and is hard to crank back. Fuel pump was replaced in March after purchasing Jeep. New fuel filter. Good pressure at the rail. New TPS. Proper voltage at map sensor. It’s dying as if it’s losing voltage because the lights blink. I’m stumped
  2. Nov 3, 2018 at 11:06 AM
    wHAT LIGHTS BLINK - body or dash?
    1996 GOOD have a good diagnostics on board.
    So step 1 Always is to SCAN and post ALL codes...
    good voltage at MAP - what is that? referance? signal? ground( good no stray V)?
    Fuel pressure is PSI?
    Lets try this As someone tries to start jeep spray some starter fluid or carb cleaner into TB - did it 'hit' try to start or run on the spray ?
