Jeep Engine VIN??
Discussion in 'CJ' started by CJ-Zacos, Mar 16, 2017.
  1. Mar 16, 2017 at 6:12 PM
    CJ-Zacos
    CJ-Zacos [OP] Member
    1983 CJ-5 Renegade
    Got to where I am pulling apart my 1983 CJ -5 Jeep Renegade and was wondering if the 258 4.2 Straight 6 that's in it was the original engine that came in this Jeep. I found the Stamping for the Build Date that Reads "207C12" which from research Decodes into 07/12/1982 and the C being the correct engine and the date looks about right to me, but I can not seem to find a VIN anywhere on the Engine. I did some searching and it looks like I see a lot of people saying Jeeps did not stamp VIN anywhere on the block. Does anyone know if this is true...if not where should I look for it?
  2. Mar 16, 2017 at 9:39 PM
    I'm not aware of it being on the block either.
