Jeep JL Factory Technical Support
Discussion in 'Wrangler JL (2018+)' started by agelotti, May 18, 2018.
  1. May 18, 2018 at 6:52 PM
    agelotti
    agelotti [OP] Member
    Anthony
    2018 Wrangler Unlimited JL Rubicon
    None
    Does anyone know how to contact a factory tech rep to discuss what is needed to safely flat tow the new JL. Has Jeep solved the death wobble issue with the new wiring harness? Is it possible to eliminate the steering drift experienced with the JL?
  2. May 18, 2018 at 7:24 PM
    Not an expert on JLs but death wobble due to wiring harness?
  3. May 18, 2018 at 7:28 PM
    agelotti
    Anthony
    None
    Not due to wiring harness, Jeep is coming out with a special wiring harness for the JL. Is this wiring harness designed to eliminate the death wobble?
  4. May 18, 2018 at 7:30 PM
    agelotti
    Anthony
    None
    The death wobble of front steering is due to electric motor assisted power steering
  5. May 18, 2018 at 7:33 PM
    Wow that could explain the connection with the wire harness for JLs. I only know about the other typical causes of death wobble in older jeeps
  6. May 21, 2018 at 9:59 AM
    Any link to published information regarding this?
  7. May 22, 2018 at 8:04 AM
