Jeep lover for life
Discussion in 'New Member Introductions' started by 3del, Mar 12, 2022.
  1. Mar 12, 2022 at 7:40 AM
    3del
    3del [OP] New Member
    Frank
    2000 tj
    3" lift
    Greetings everyone,
    I have owned some Jeeps over the past 20 something years. I have owned two TJ's, four Cherokee Sports and one truck. I grew up working on 1960's through 1970's GM's muscle cars. There has never been a better engine than the inline six 4.0 for longevity. I know I'm not telling you all nothing you do not already know. I have put so many miles on theses engines it's hard for me to believe. Anyway expect to hear from me asking questions and maybe share some of my experience should someone need it.
    o|||||||o, Bob, tomrr and 2 others like this.
  2. Mar 14, 2022 at 6:52 PM
    Welcome! Any pics
  3. Mar 14, 2022 at 6:59 PM
    3del
    Frank
    2000 tj
    3" lift
    sorry Bob no I have not documented well.
  4. Mar 17, 2022 at 6:58 PM
    Jeep Ride
    Jeep Ride Member
    You can't go wrong with a Jeep.
  5. Mar 18, 2022 at 5:46 AM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    Well I certainly went wrong with the JK. Pain in the a$$ from day one-new from the dealer. It has NOT improved with age.
  6. Mar 18, 2022 at 6:31 AM
    Jeep Ride
    Jeep Ride Member
    Sorry to hear what kind of problems have you had?
  7. Mar 18, 2022 at 6:29 PM
    MTgeezer
    John
    55 CJ 3B
    It was back to the dealer 22 times under warranty. All perhaps 6 of those were electrical. It's paradoxical in that yes, the JK was more capable (at least the Rubicon version) off road out-of-the-box than all the previous models but, IMO, still way short of what it should have been. From the very basics of an engine really ill suited for off road (zero usable bottom end torque-the 4.0 was better), a PS system totally inadequate for that same use, axle tubes that are laughable along with their tin foil brackets, in my case the No Significant Gear 370 transmission that will not stay in gear with the stock shifter, death wobble at 30 something k miles, and a wiring harness that is really unfixable. The list could go on like the only option we ordered: leather seats. Check that. Leather TRIMED seats that have cheap a$$ vinyl on the bolsters which didn't last 20 k miles---In short, Jeep excels at building mall crawlers. But it isn't anything that can't be fixed with new aftermarket axles, brakes, suspension, transmission, engine, wiring, PS, and at that point no use sticking with the 241OR-may as well put a Atlas in there with a real low range. But then why stick with a JK tub? All sorts of more interesting platform options at that point.
    I learned to drive in a Willys 2A when I could finally slide off the seat far enough to reach the pedals. That was 1955. I took my driver's license test in an 1957 FC 150 in 1959 and I've pretty much had Jeeps ever since. But I'm really over fiat and stellantitis (inflammation of one's posterior from repeated butt f-----. The JK will be going to someone else when the current vehicle availability sorts its self out and I will be wheeling one of those more interesting platforms-the 1955 Willys CJ 3B. Much more interesting in this case.
    JKBob 25 and Jeep Ride[QUOTED] like this.
  8. Mar 19, 2022 at 6:29 AM
    Jeep Ride
    Jeep Ride Member
  9. Mar 19, 2022 at 6:30 AM
    Jeep Ride
    Jeep Ride Member
    What year model was your jk ?
  10. Mar 19, 2022 at 8:13 AM
    MTgeezer
    John
    55 CJ 3B
    2012. There was no way I could take the 3.8. I drove a few of them. The 3.6 is obviously better but insufficiently better and obviously, with its own set of problems. I've owned someplace around 40 vehicles in my career and the JK is the only one that ever earned a moniker. Its name is pause. Spelled POS. It still only has 62k on the odometer. The big question now is what to replace it with. There are more than a few things I don't like on the new Broncos. Maybe it is time to build a Willys wagon. I have both a 51 and a 57 that could be used for that. The 51 actually is almost entirely rust free. And the push button doors are kind of cool.
  11. Mar 19, 2022 at 8:24 AM
    Jeep Ride
    Jeep Ride Member
    I saw last night a 71 bronco sold at the Mecum auction for 90k , The idea of building a Willy's sounds like a good idea I learned to drive a standard shift in a 48 Willy's cj my Dad used to own he also had a 49 Jeepster he bought for 15 dollars at a junkyard this was around 1970 good times.
    MTgeezer likes this.
