Jeep problems
Discussion in 'Wrangler JK (2007-2017)' started by Chris252, Jul 9, 2019.
  1. Jul 9, 2019 at 12:46 PM
    Chris252
    Chris252 [OP] Member
    CHRIS
    2ND OWNER GREAT PUMPKIN
    3 inch lift 35s
    Having troubles with my transmission on my 2011 jeep wrangler did a flush and changed filter but I'm not sure that's gonna fix it apparently its slipping but I cant feel it what should I do next dont want to change the whole transmission I just bought the jeep a couple months ago wtf
  2. Jul 9, 2019 at 1:19 PM
    What's the mileage? What do you mean "apparently it's slipping but I can't feel it"? Flush and filter change is a good first step but how was the trans fluid color, smell, consistency? Generally a single flush doesn't capture all the old fluid as a lot remains within the trans and converter. Hoping everything works out.
  3. Jul 9, 2019 at 1:57 PM
    Chris252
    CHRIS
    3 inch lift 35s
    82000, yes I mean apparently its slipping and there was no metal flakes in the pan and the fluid was a little gnarly I was told had my mechanic do it he said next step if it messes up again is the solenoid hope I spelled that right lol just trying to get other people's opinions too maybe someone has gone through it befor
  4. Jul 9, 2019 at 3:12 PM
    Some thoughts:
    A 'flush' - some questions-
    1) did you do this or a shop?
    2) What fluid did you use? be specific if you can.
    3) A scan may show if there are issues, you will need to use a SCANNER - try the free scans that many par stores do. did I mention FREE. :)
    FYI: trans issues often will not turn on CEL and a scanner is needed to see them.
  5. Jul 9, 2019 at 3:33 PM
    The transmission quit on my LJ at about 130k miles it didn't start slipping it just quit I think the 33's I put on was the last nail in it's coffin. I had no signs it was going out it just quit lol
  6. Jul 9, 2019 at 4:41 PM
    Not sure on Jeeps but on Hondas with the flashing D symbol a basic DIY code reader shows nothing. Pro scanner showed PO700 which is a generic code that the PCM detected a malfunction in the trans control system. That required a trip to dealer to identify the exact trans malfunction which turned out to be a solenoid but ymmv.
  7. Jul 10, 2019 at 3:47 AM
    SIMPLE - the CEL and p0700 - a transmission problem has requested the light on. there are transmission codes. The key on off trick and or cheap code readers may not display the codes.
    All DIY'ers should get a capable scan tool - your not Dr Seuss, A carpenter needs a hammer, A plumber a wrench, A MD a financial adviser, you gotta have the right tool.
