Jeep shakes at really low speeds
Discussion in 'Wrangler JK (2007-2017)' started by You78, Jul 19, 2019.
  1. Jul 19, 2019 at 4:22 PM
    You78
    You78 [OP] New Member
    So I just did about a 2hr drive and about 30min from getting home I noticed, slowly starting from a stop the front end of my jeep starts to shake, but as I kept going eventually it would stop.(Keep in mind that as this would happen only going under 5mph). Once I got home my dad and I did some investigating.( Forgot to mention I did go offroading while omw home and had the jeep in 4wh, but then disengaged it once I was done.) We found out that the front end only shakes when in 2wd at really low speeds.
    The jeeps a 2018 jk, 4 inch lift on 35's. Only has about 6000 miles on it and where taking it to the dealer in a few days. Just wanted see if anyone has had this problem before
  2. Jul 20, 2019 at 2:27 PM
    Let the dealer figure it out. Hopefully it has nothing to do with the tires or suspension lift.
  3. Jul 20, 2019 at 6:54 PM
    Welcome to the forum @You78 .
    Did you install the lift? Or did you have a local shop do the work? The dealership?
    If I'm not mistaken. A dealership will warranty the Jeep with a 3 inch or less lift. Is it still under warranty?
    If you were offroadin. Is it possible you broke or bent something?
  4. Jul 20, 2019 at 8:22 PM
    You78
    Yea I had it done by a local shop, and I think it's still under warranty. But what is weird is I went offroading about halfway through my trip. I didn't notice the problem till about an hr down the road.
  5. Jul 20, 2019 at 9:17 PM
    Recent suspension work then some off roading......get the lift parts checked as something either got loose or bent. Part of the build story.
    o|||||||o and JKBob 25 like this.
