Jeep wobbles
Discussion in 'Suspension' started by Debjeep64, Aug 23, 2019.
  1. Aug 23, 2019 at 7:54 AM
    Debjeep64
    Debjeep64 [OP] Member
    2007 unlimited
    Hey there. Ssdj. I have a 2007 jk, w 300,000+ miles but runs amazing.
    I have replaced all my tie rods, tie rod ends, sway bar bushings, upper and lower ball joints, both sides, wheel bearing assemblies, shocks, steering stabilizer (where this all began), and most recently re-replaced a tie rod that was defective. And I still hit a series of bumps that set the wobble off again. Much less violent than usual, and stopped at a slow speed not a full stop but...
    I was wondering I'd anyone can tell me if steering damper works in both directions or just 1?
    Also, any other suggestions?
  2. Aug 23, 2019 at 4:53 PM
    Yes. It works in both directions.
    After replacing everything you mention. I'd check tightening torques, And all bushings. Also...there is only one tire rod on the front suspension. So I'm not sure what you mean by "tie rods".
    There is a misconception on steering stabilizers. In most, if not all, wobbling conditions start else where. Another front end issue. And a new stablizer just hides the true problem. And only temporarily.
  3. Aug 24, 2019 at 12:33 PM
    When was the last time you had a wheel alignment guy look at it. As goes the phrase " Let the baker bake the bread".
  4. Aug 24, 2019 at 12:53 PM
    Debjeep64
    2007 unlimited
    Well Donald, I had a real Baker look at and align it after 'I" replaced the broken steering stabilizer. Then again after the tie rod and tie rod end. And a third time after all 4 ball joints and 2nd replacement of defective tie rod. Also I had all 4 wheels balanced.
    Any other advice for me?
  5. Aug 24, 2019 at 5:58 PM
    Find another baker. They should also be able to determine if your tires are coming apart, which is another possibility.
  6. Aug 24, 2019 at 7:44 PM
    Guess you missed my post. :notsure:. Torques....bushings.... Sorry to say. Not every mechanic knows what their doing. Doesnt hurt to get a second opinion.
    Nope....no other advice. Appears you got it covered. :pout::popcorn:
    BigNuge likes this.
  7. Mar 18, 2020 at 10:57 AM
    dancar
    dancar Member
    07WranglerX
    Stock
    I have a 2007 jk wrangler (two door), low mileage, with front end wheel/steering oscillation issues (ie death wobble) - and - all front end and suspension components are sound!, tight - torque specd, in excellant condition - excellent tires, stock wheels, ...
    My thoughts after looking into this for several months - it may be caused by unexpected wear inside the steering box.
    What else is there?
  8. Mar 18, 2020 at 12:17 PM
    Usually the steering box is the last thing to go bad. If you have the steering oscillation issues like when you drive over a railroad crossing or a rut in the road it is probably worn tie rod and drag link ends. An easy way to check them is to squeeze them with a pair of channel locks. Another possibility can be worn wheel bearings. I will see if I can find a YouTube video on this.
    Like this :https://www.youtube.com/watch?v=6M2D_XtuXZQ
    Or this:https://www.youtube.com/watch?v=brI2feYiEi8
