Jeep won't idle after changing power steering pump
Discussion in 'Grand Cherokee' started by Arkangel1200, Oct 5, 2021.
  1. Oct 5, 2021 at 2:15 PM
    Arkangel1200
    Arkangel1200 [OP] New Member
    Zack
    2004 Grand Cherokee
    I have a 2004 grand cherokee with a 4.7 and the power steering was going out so I decided to just go with an O'Reilly power steering pump.
    I put it back together and First it blew some of the power steering lines with the old school clamps underneath the upper radiator hose (Not sure which lines they are). Put good clamps on them and the jeep will start but not idle.
    The power steering pump doesn't sound good either. Doesn't make any sense cuz all I did was the power steering pump and now it won't idle?
    My best guess is the pump is so bad it's causing so much drag on the pulley that it kills the engine? Idk. As well I smell a little fuel when trying to start it. Very weird. Ran fine before btw
  2. Oct 6, 2021 at 6:49 AM
    Might want to confirm part application. the 4.7L uses a special PS pump. IIRC the fan is hyd driven (PS fluid)
    Not idling - poor idle - always start with cleaning IAC BUT it ran before pump SO I doubt it clogged with eng off .
    did you disconnect battery? 'Might' need idle relearn
    If NO then check for codes - even if CEL is off.
  3. Oct 7, 2021 at 5:04 AM
    gowenby2002
    gowenby2002 Member
    Gordon
    Jacksonville, FL
    2002 white TJ 4.0 auto
    stock late model wheels/street tires with adapters, 7 in. stock type fender flares, 4 core rad/elec.fan, all LED lights, spray-in bed liner in cab, front home-made tow brackets for flat-tow
    Also might check all vacuum lines and connectors you might have knocked off or broken if they are old as they become very brittle.
