Jeep xj electric fan wiring question
Discussion in 'Cherokee' started by Valkyriessong, Aug 25, 2019.
  1. Aug 25, 2019 at 2:55 AM
    Valkyriessong
    Valkyriessong [OP] New Member
    Joshua
    93 jeep xj
    4.5in lift front 5in rear rebuild 4.0 board 3 over
    I am wireing my jeep xj fan, I have a wire too the battery with a blade fuse to the toggle in the cab,then I spliced into the fan power (leaving it still wired to the stock system) and running into the cab too the toggle.... the question is do I need a relay between the cable I'm running from fan too toggle and why do I need one? Thank you
    Edit Quote
  2. Aug 25, 2019 at 6:16 AM
    Slow down - time to think
    I am confused AND its early 1st coffee - Sounds wrong on first reading, you want to power the fan @40amp thru a toggle switch in dash? And you are debating using a relay?
    GTG
  3. Aug 25, 2019 at 6:32 AM
    Welcome @Valkyriessong ...those fans could be drawing over 20 amps so relays should be part of the wiring diagram.
  4. Aug 25, 2019 at 6:55 AM
    confusion continues
    Is this a 1993 XJ ?
    did that MY year come with a elec fan?
    a QUICK LOOK i DID NOT SEE AN ELEC FAN so i AM ASKING BEFORE LOOKING....
    WHY what - are you adding an elec fan and a switch -
    sORRy sticky cap KEY
  5. Aug 25, 2019 at 7:15 AM
    Don't you mean OMG or WTF or GOML (get off my lawn)
  6. Aug 25, 2019 at 6:14 PM
    :rofl::rofl:.
    @Valkyriessong . Try to ignore the shinanagins above. :rofl:But yes. You should wire a relay close to the battery.
    aggrex[QUOTED] likes this.
