JK 2010 won't crank
Discussion in 'Wrangler JK (2007-2017)' started by jrgrajales, Sep 29, 2019.
  1. Sep 29, 2019 at 2:08 PM
    jrgrajales
    jrgrajales [OP] New Member
    Javier
    RHD Jeep Wrangler 2010
    My RHD jeep wrangler sometimes won't crank ! any help what can it be ?
  2. Sep 29, 2019 at 2:17 PM
    Welcome @jrgrajales ...start with the basics before anything else. How old is the battery? Starts with a jump? How old is the problem? Get the battery load tested at auto parts stores like advance/autozone. While you're there they should be able to check the charging system. Sometimes it could simply be connections, bad grounds or the starter. But one step at a time.
  3. Sep 29, 2019 at 2:21 PM
    jrgrajales
    Javier
    battery is new, the starter makes no sound, it is as if no electricity comes to it!
  4. Sep 29, 2019 at 6:53 PM
    Based off your description (no sound) guess its like trying to start in gear. Just a few more questions: Intermittent no start? Jump start-able? Have you tried to wiggle the AT shifter into PARK or try to start in NEUTRAL?
  5. Sep 30, 2019 at 6:05 AM
    Still there - hello -
    Can we find out a little more- automatic or manual?
    Can OP do simple electrical tests with a test light?
