Knocking in front end suspension
Discussion in 'Wrangler TJ (1996-2006)' started by Schaefer91, Mar 24, 2018.
  1. Mar 24, 2018 at 10:42 AM
    Schaefer91
    Schaefer91 [OP] New Member
    Kurt
    04 tj rubi
    Took it off roading and now there is a knock coming from the front end whenever the suspension is flexed. None of the joints seem to have any play... not very mechanically inclined. Any tips on what it might be and how to check
  2. Mar 24, 2018 at 11:05 AM
    Welcome to the site! I would start with checking to make sure nothing is loose, or looks broken. Might want to have a friend assist with listening for the location the sound is coming from.
  3. Mar 24, 2018 at 11:08 AM
    Schaefer91
    Kurt
    04 tj rubi
    Yes tried that nothing looks bent or out of place. But it's a pretty aggressive knock, you can feel it in the floor board.
  4. Mar 24, 2018 at 11:37 AM
    I would get a friend to help find the location of the sound. Try to flex it with them outside near the front to identify the location.
  5. Mar 24, 2018 at 12:07 PM
    Welcome! Hope you practiced tread lightly on the trail. The suspension is tough but driving hard and quick can damage components. Flex the suspension with a helper as chris4x4 described and inspect suspension parts (tie rod>drag link>etc) for looseness because looks can be deceiving. Shock mounts or control arm bolts or ball joints could be worn/loose for example. All a part of jeepin....break>replace>break again...the upgrade method
  6. Mar 24, 2018 at 1:33 PM
    Schaefer91
    Kurt
    04 tj rubi
    It was the passenger sway bar end link.
  7. Mar 25, 2018 at 7:07 PM
    Welcome to the forum. Awesome you found your fix so quickly. Hope previous posters helped.
