Largest tire size on a '79 CJ7 w/ a 4" lift?
Discussion in 'Wheels & Tires' started by Blaise110, Sep 15, 2017.
  1. Sep 15, 2017 at 8:00 PM
    Blaise110
    Blaise110 [OP] New Member
    Blaise
    '79 CJ7
    4" Lift Kit
    What's the largest tire I can run on a '79 CJ7 w/ a 4" lift
  2. Sep 16, 2017 at 5:25 AM
    Welcome! This forum has several active CJ owners that can guide you in your quest. Perhaps stating what your currently running and some pics would help them make recommendations.
  3. Sep 16, 2017 at 7:58 AM
    Welcome!
  4. Sep 16, 2017 at 7:00 PM
    Welcome to the forum dude. As stated. Numerous CJ guys here. Hang tight. What are you running now? Have you regeared or planning to?
  5. Sep 19, 2017 at 6:59 PM
    daddyusmaximus
    daddyusmaximus Well-Known Member
    '79 CJ5
    You could probably run 33s if you don't get too twisty on the trails with it. You'll need the gearing to go with it. I've seen 35s in a low COG set up with only 4" of lift a couple of times, but not without plenty of trimming the tub and fenders.
  6. Sep 19, 2017 at 7:12 PM
    33x12.50s on a 15x8 in rim. If you get the Metal Cloak fenders 36x12.50 on 15X10s
