Largest tires on an 01 Grand Cherokee?
Discussion in 'Wheels & Tires' started by Bashelton65, Nov 25, 2017.
  1. Nov 25, 2017 at 4:53 PM
    Bashelton65
    Bashelton65 [OP] New Member
    Michael
    01 grand cherokee
    None
    I'm currently trying to figure out what the biggest tire is I can fit on my 01 grand Cherokee. Looking at 285s but I don't know if they will fit?
  2. Nov 25, 2017 at 7:17 PM
    Hey Bashhelton65. Welcome to the site. Based on your a avatar listing. Can I assume you don't have a lift installed? I'm not familiar with 01 GCs. But 285s are basically a 33 x 11 inch tire. Without a lift. I beleive you may have rubbing issues.
    Hang tight. I'm sure a member or 2 with more experience will chime in. Seems like most of our people are suffering from Turkey hangovers. Lolll. o_O.
  3. Nov 25, 2017 at 8:55 PM
    Welcome aboard!!
  4. Nov 25, 2017 at 11:06 PM
    Welcome! Without a proper lift your options are limited. OEM tires are 245/70-16 or 235/65-17
  5. Nov 26, 2017 at 6:41 AM
    Bashelton65
    Michael
    01 grand cherokee
    None
    Thank you guys I figured the 285s were to big.
  6. Nov 26, 2017 at 6:59 AM
    Bashelton65
    Michael
    01 grand cherokee
    None
    Would a 2" lift allow you to fit the 285s?
  7. Nov 26, 2017 at 7:10 PM
    285 is the width of the tire. 285= 285mm wide divide by 10 = 28.5cm divide by 2.54= 11.22 inches wide. What are the rest of the numbers? For example: 285/75r16 This is Metric for 33x11.00x16.
    I will post a thread on how to get the correct measurements on a tire in what I call metric/European form soon.
  8. Nov 26, 2017 at 7:19 PM
    Discount tire says the largest tire on a factory rim on a stock 2001 GC that you can run is 265/75r16. This is appoximately 32x10.50x16. I don't know if 2 inches would be enough to get you to 33s or 285/75r16s.
