LED Upgrade 1985 CJ7
Discussion in 'CJ' started by dagersh, Feb 4, 2022.
  1. Feb 4, 2022 at 3:00 PM
    dagersh
    dagersh [OP] Member
    Michael
    1985 CJ7 Laredo
    2.5" Lift
    Hi Guys,
    I have upgraded my exterior lighting save the headlights to LED. I am using an LED (Electronic) Flasher. Everything works great, until I use an 1157 LED in my Taillight. On my Jeep, this light handles Tail, Brake and Turn (there is a separate 1156 for Reverse). With an incandescent 1157, everything works, but not with the LED...
    Any ideas what is wrong? I upgraded many cars and motorcycles to LED lighting, but I have never had this issue before. I can't imagine its a ground issue due to the incandescent lightbulb functioning perfectly...
    Thanks!
    Gersh
  2. Feb 4, 2022 at 8:38 PM
    On a different vehicle, all the LEDs (canbus-friendly and resistor-free) worked except the LED front turn signal triggers hyper flash. My preference was to have instant-on + brighter LED rear tail/stop/turn so out came the LED front turn signal. On your Jeep what happens when the 1157 LED is installed in the tail light? Anything works? Did you consider splicing in a resistor?
  3. Feb 4, 2022 at 10:03 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Should work. There are no incandescent bulbs anywhere on my Jeep inside or out. I put in a $8 electronic flasher, no hyper-flash, no resistor needed. I have yellow and red led's because all of the lenses are dark smoked and my turn and brake lights are still a lot brighter than the stock lenses/bulbs. Did you change the front turn signal bulbs to led also? Not going to work right with any incandescent bulbs on the circuit.
  4. Feb 6, 2022 at 11:00 AM
    dagersh
    dagersh [OP] Member
    Michael
    1985 CJ7 Laredo
    2.5" Lift
    Aggrex - The lights all light, but with the 1157's in the tail units, no flashing. I have never needed additional resistors with the electric flasher unit installed.
    Groudfault - all the lights, except for the 1157's in the taillight housing are currently LED - the signals work. If I use the LED 1157 in the taillight, it won't flash at all.
    I should add that the signals in the Speedometer are lit with incandescent. I need to pull the dash and replace everything behind it with LED's as well.
    Thanks for the responses!
    Gersh
