Looking for 5 speed transmission with adapter kit
Discussion in 'CJ' started by Leocj5'79, Dec 12, 2021.
  1. Dec 12, 2021 at 7:20 PM
    Leocj5'79
    Leocj5'79 [OP] New Member
    Leonel
    1979 cj5 base
    Holly sniper EFI fuel injection
    Hi everybody , there's any way I can find a complete adapter to install a 5 or 6 speed transmission on my 79 cj5 ? Thanks
  2. Dec 19, 2021 at 8:07 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    T-150 transmission now?
    T4/T5 is longer and you'll need the dana 300 transfer case with it. Bell housing, transfer case, tranny support/mounts, tunnel cover and skid plate will need to be changed/modified. Front and rear driveshfts will need to be changed. Rear will be quite a bit shorter which will increase the angle to differential.
    Can be done, but not going to be a simple drop and swap.
