Low oil pressure cause?
Discussion in 'Other Jeep Vehicles' started by Festus, Mar 16, 2018.
  1. Mar 16, 2018 at 5:55 AM
    Festus
    Festus [OP] New Member
    Festus
    Keep Comanche
    I have a 1992 Comanche six cylinder that needs a rebuild. I was told there is a fix to what is causing low oil pressure. Does anyone know the cause of the low oil pressure. One engine builder said he thinks it's a cam bearing problem and a head gasket issue. But he did not know the specifics.
  2. Mar 16, 2018 at 7:42 AM
    Welcome aboard! I cant help with the issue, but hopefully someone can pop in with some assistance.
  3. Mar 16, 2018 at 9:43 AM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    usually worn bearings if the pump is good. pumps are usually ok.
    bearings; cam, main, rod.
  4. Mar 16, 2018 at 9:50 AM
    Welcome! Our guess for low oil pressure could be inaccurate until the engine components are inspected or replaced during the rebuild. Check for a TSB for a low oil pressure issue but regardless worn or defective parts will be discovered during the rebuild or perhaps a 4.0 owner may chime in.
  5. Mar 17, 2018 at 7:18 PM
    Welcome to the forum @Festus. Just my thoughts. If your looking at a complete rebuild. In most cases as far as time is concerned. And it will cost you just about as much cash. Look into a remaned motor. Years ago I cooked my XJ motor and cracked it. Buying a recycled block, parts and man hours to do rebuild. I opted for a Jasper remaned motor which just dropped right in. Back on the road the next day vs a possible 4 - 5 days, if your lucky, for a total rebuild. Plus just like a starter or battery. They give you credit for the core. Just a thought. I put approx. 190k on that Jasper motor.
