Low tire pressure light on
Discussion in 'Liberty' started by biff, Oct 8, 2022.
  1. Oct 8, 2022 at 10:44 AM
    biff
    biff [OP] New Member
    Paul
    2011 jeep liberty
    stock
    I have an aftermarket stereo installed and the steering wheel buttons do not work
    Any ideas on how to reset the light?
    thanks
  2. Oct 8, 2022 at 11:36 AM
    Pump the tire to spec psi in owners manual and the TPMS light should go away after a short drive. Generally the TPMS sensors are good for about 7-12 years +/- perhaps one has failed
    Dirty Dog, JKBob 25 and Bob like this.
  3. Oct 9, 2022 at 9:00 AM
    Dirty Dog
    Dirty Dog Well-Known Member
    Mark
    2011 & 2013 JKU Rubicon
    Check your pressures. If they're normal, then the sensor is likely bad. Beyond that, if you want help you'll really need to provide a bunch more information. We don't even know what sort of Jeep or stereo you're talking about. An older Jeep with OBD 1 will require a different approach than a newer one.
  4. Oct 20, 2022 at 6:53 AM
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    Yeah, check pressures. If you do need to change a sensor it’s pretty simple and a $10 part
