Mechanical fuel pump issue
Discussion in 'CJ' started by Rmillerjr24, May 11, 2024.
  1. May 11, 2024 at 8:33 AM
    Rmillerjr24
    Rmillerjr24 [OP] New Member
    Roger
    86 CJ7
    I have a 86 CJ7. 4.2. . This thing is going through fuel pumps like crazy fast. I have bought out all the fuel pumps at all the parts stores I'm my area and this issue has got me stumped. I have put on a fuel pump regulator and gauge so with that I'm guessing it's working at least the gauge shows it is. I literally put 5 miles on the pump I installed last night. I don't know any input is appreciated thanx.
  2. May 11, 2024 at 6:52 PM
    rick1956
    rick1956 has dirty fingernails
    Rick
    Edgewood, Washington
    81 CJ-7
    Lots of mods, but they were already in place. MY mods are REPAIRS!
    That might signal that the pump lever is being pushed too far for whatever reason. In the old small block Chevy world for example, it wasn't unheard of the have the rod between the cam and the fuel pump to be the wrong length, overdriving the pump and destroying it. Any chance it could be for another model?
    Engir, shooter65 and aggrex like this.
  3. May 13, 2024 at 6:31 AM
    258 Rocket
    258 Rocket Member
    Aaron
    Stock (with improvements)
    You can try an electric fuel pump conversion.
    shooter65 likes this.
  4. May 13, 2024 at 8:43 AM
    Rmillerjr24
    Roger
    86 CJ7
    Thanx for the info I ended up changing it over to electric fuel pump. I just couldn't keep dealing with that. But I definitely still want to figure out why it's the craziest thing. It just didn't make sense. But again thanx for the info
    shooter65, aggrex and JKBob 25 like this.
  5. May 23, 2024 at 6:14 AM
    shooter65
    shooter65 Well-Known Member
    Southwest PA
    2023 Rubicon 4 Door
    I believe @rick1956 was spot on that the root cause is with the fuel pump rod. For many years before Mopar bought Jeep, they used to source parts from several manufacturers within the same model/year. If the rod length and pump don't match, bad things will happen. It would be interesting to see the wear condition of the pump rod.
