Moon Roof leaks
Discussion in 'Grand Cherokee' started by notsofastbud, Aug 31, 2020.
  1. Aug 31, 2020 at 6:36 PM
    notsofastbud
    notsofastbud [OP] Member
    jimB
    Live Free or Die State N'AMSHA USA
    2002 Grand Cherokee Laredo very well optioned well cared for 135K second owner
    Good day all,
    An issue with my 2003 Grand Cherokee Laredo just popped up. Just opened the moon roof for the first time since recent purchase.
    Jeep is equipped with a power moon roof (glass)
    Noticed a wet spot/stain on the headliner/sunshield
    I checked to see if roof was fully closed and it was. Seems to cycle OK with seal where it should be when closed.
    I cleaned the seal and roof and lubed it with some silicone spray. Drain openings are clear; I will flush.
    Before I get into it, is there a way to replace the weather seal without taking half the Jeep apart?
    Any input/ observations?
    Did a fast cruise of Youtube; nothing obvious popped up.
    TIA
    jimB
  2. Aug 31, 2020 at 6:49 PM
    I tend to avoid power moon roof whenever possible. Clean excess debris from the channel/track. Try using compressed air down each drain opening before flushing with H2O. Inspect the seal for tears and integrity. Smaller tears or holes could be closed with some silicone glue.
    LYFZGOOD likes this.
  3. Sep 2, 2020 at 6:49 AM
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    Can try a window seal to it? I did for my freedom top that had leak issue and it did the trick. You can get it at Lowe’s or local hardware store. It’s easy to cut down to size you need.
