Motor Ticking
Discussion in 'Wrangler TJ (1996-2006)' started by Warrenb, Jan 25, 2018.
  1. Jan 25, 2018 at 2:18 PM
    Warrenb
    Warrenb [OP] New Member
    Black 2000 TJ
    wheels, tires, exhaust
    I have a 2000 TJ. motor ticks constantly but have been told it is not the motor its self. motor runs fine but has that constant tick especially when it is cold like in the mornings. sometimes the longer it runs or is driven the ticking gets more quiet
  2. Jan 25, 2018 at 3:27 PM
    Welcome to jeeps.net! Try some synthetic oil since they flow better in low temperatures. Constant ticking due to mileage or wear may not have dramatic improvement.
  3. Jan 25, 2018 at 4:06 PM
    Cracked exhaust manifold will tick too.
    The 4.0 exhaust manifolds all crack.
  4. Jan 26, 2018 at 6:56 AM
    Welcome aboard!
  5. Jan 26, 2018 at 7:38 PM
    Welcome to the forum Warrenb.
  6. Jan 27, 2018 at 4:31 PM
    mudbug85603
    mudbug85603 Active Member
    Jim
    Upstate SC
    Be sure you're using 10w30 motor oil and a quality oil filter, like the Mopar oil filter. The 4.0 takes 6 quarts of oil no more no less. If there is more or less than 6 quarts the motor can tick. Exhaust manifold crack is a real thing and will happen to 90% of all 4.0 motors. Be sure the rocker bridge capscrews are tight to spec
    It's also possible you have a broken piston skirt. That will be a louder ticking almost a quiet knocking sound.
    OFFGRID, JKBob 25 and aggrex like this.
  7. Jan 27, 2018 at 4:59 PM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    my 2000 has a "clatter" that quiets a little when warm. did it 16 months ago when i bought it at 168000. still same now at 176000, 8000 miles. some say piston slap,?? runs great,smooth, gutsie!!
    oh, using 15/40 t4 rotella,makes no difference what oil.
  8. Jan 27, 2018 at 6:42 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    If its lifters its more of a ticking sound. If its piston slap its because the piston skirts are worn, cylinder worn etc, and sounds like a metallic sound (dull knock or tapping ) and is more noticeable when first started and may then go away or less noticeable after its warmed up. You do have a few miles on the engine so wear would be expected. Good luck
  9. Jan 27, 2018 at 6:58 PM
    Awesome advice given. Keep us posted. This could help others in the future.
