Name of part that sits on top of carburetor?
Discussion in 'Cherokee' started by Countrygirl15, Apr 13, 2019.
  1. Apr 13, 2019 at 8:46 AM
    Countrygirl15
    Countrygirl15 [OP] Member
    Melissa
    2002 Jeep Grand Cherokee laredo
    What is the part called that sits on top of the carburetor for air flow
  2. Apr 13, 2019 at 10:04 AM
    That is likely the throttle body.
    PLEASE let us help you. describe the issue AND if known what codes is system showing.
    The people at part stores are there to SELL parts yes they will assist with codes but I must mention a code does NOT condemn a part - the part it indicates is often just the messenger.
    EXAMPLE - fuel sensor - indicates low fuel - would you first replace sensor?
  3. Apr 15, 2019 at 6:37 AM
    Countrygirl15
    Melissa
    My jeep is throwing a code for the 02 sensor, I know that but I was asking only because when I got to start my jeep it takes like 2 or 3 times for it to turn over. I thought it might be the clean air resonator.
  4. Apr 15, 2019 at 7:16 AM
    Do you mean it has to crank over 2 or 3 times before it will finally fire up or do you have to turn the key 2 or 3 times before it will do anything?
  5. Apr 15, 2019 at 7:53 AM
    Countrygirl15
    Melissa
    I have to turn the key 2 or 3 times before it will fully fire up.
  6. Apr 15, 2019 at 7:56 AM
    If it doesn't do ANYTHING the first couple of key turns you might try putting it in Neutral first and see if that helps. If it does you might look at cleaning the Neutral Safety Switch (NSS), you can replace them but a lot of the times just cleaning and re-greasing it can help.....if you can get it off without breaking it.
    If it is doing something, just not starting that could be a completely different issue.
  7. Apr 15, 2019 at 8:05 AM
    Countrygirl15
    Melissa
    another question you may know....do you know how many o2 sensors a 2002 jeep grand Cherokee Laredo has? and where they are located?
  8. Apr 15, 2019 at 8:29 AM
    2 if it's a federal emissions engine (one in the down pipe, one after the catalytic converter), 4 if is a California emissions engine (2 in each down pipe before the catalytic converters, and 2 after).
    http://wjjeeps.com/oxygen.htm
    Shenanigansjeep4x4 and aggrex like this.
