Need a photo of belly pan under transfer case of a 78 CJ 7
Discussion in 'CJ' started by pastor scott, Oct 6, 2018.
  1. Oct 6, 2018 at 9:55 AM
    pastor scott
    scott
    1978 CJ 7
    none right now
    Hey guys
    So I picked up this beat up 78 cj 7 .3 speed manual. V8
    After crawling around I saw something I don't like . Seems the belly pan under the transfer case is not right. Seems too wide past the frame rails .like they took it off something else. OR .maybe that's how it is. Can one of you check your cj and see if yours is flush with the frame rails or is wider. If you don't get what I mean I will send a photo .
    Thanks
    Ps Scott
  2. Oct 6, 2018 at 10:11 AM
    Hi, post a photo of how yours looks
  3. Oct 6, 2018 at 10:47 AM
    pastor scott
    scott
    1978 CJ 7
    none right now
  4. Oct 6, 2018 at 11:04 AM
    That looks correct. The same belly pan fits multiple applications from the CJ to the Fullsize Jeep (FJ), and all of the different motor and transmission applications too. There should be several holes drilled at different widths as well to accomodate the different applications.
    LYFZGOOD, Bob and aggrex like this.
  5. Oct 6, 2018 at 12:24 PM
    pastor scott
    scott
    1978 CJ 7
    none right now
    Cool
    This site is great. Thanks
