Need Carb Help 73 CJ 5
Discussion in 'CJ' started by bigracindaddy, Apr 3, 2024.
  1. Apr 3, 2024 at 1:15 PM
    bigracindaddy
    bigracindaddy [OP] New Member
    Randy
    1999 Jeep Wrangler
    None
    I have a 1973 Jeep CJ5 With a Carter one barrel Carb. Rebuilt The Carb Fired Right Up But Gas Is Coming Out The Nipple Next To The Fuel inlet. I guess this Is A Return Line But The Return Line Is Missing. But Even If It Was Hooked Up Don,t Think This Much Fuel Should Be Coming Out. Replaced Fuel Pump And Fuel Lines. Float Looks Good.
  2. Apr 4, 2024 at 4:04 PM
    bigracindaddy
    Randy
    1999 Jeep Wrangler
    None
    Well Turns Out The New Fuel Pump Must Have Way To Much Pressure. Installed A Fuel Regulator And Fixed The Problem. New Fuel Pump Came From Oreillys Does Any One Sale A pump That Will Work With Out The Regulator
