Need diagram for locking hubs 78 CJ7
Discussion in 'CJ' started by pastor scott, Feb 29, 2020.
  1. Feb 29, 2020 at 1:17 PM
    pastor scott
    scott
    1978 CJ 7
    none right now
    So I have the stock 6 bolt CJ7 Hub the cheaper version I need the diagram on how they are assembled does anyone have one or know where to get them thanks so much
    P Scott
  2. Feb 29, 2020 at 4:41 PM
    A local auto parts outfit should have an aftermarket repair manual that will have an exploded front axle pictorial. Chilton and Haynes are popular, it helps to get all the info you can for working on the older Jeeps.
  3. Mar 1, 2020 at 5:28 AM
    pastor scott
    scott
    1978 CJ 7
    none right now
    Thank you.
  4. May 14, 2020 at 1:01 PM
    SrdjanDV
    SrdjanDV Active Member
    Srdjan
  5. May 14, 2020 at 1:04 PM
    SrdjanDV
    Srdjan
    Maybe it would help you, I hope.
  6. May 14, 2020 at 1:11 PM
    SrdjanDV
    Srdjan
