Need help: jeep yj shakes ag 35mph
Discussion in 'Wrangler YJ (1986-1995)' started by Apacker89, Jun 25, 2017.
  1. Jun 25, 2017 at 2:00 PM
    Apacker89
    Apacker89 [OP] New Member
    Andrew
    1993 Wrangler Yj 6cyl 4.0
    I have a 93 Yj (manual trans) that currently is giving me an issue. At 30mph I get a shake with acceleration. I replaced wires and have new plugs. Also recently replaced the fuel filter. In neutral the shake is not present. The idle is normal and I have no issues until I get above 30mph durring acceleration. Where should I start?
  2. Jun 25, 2017 at 6:19 PM
    Welcome to the Forum. :jeepwave: I'm sure will be able to help.
  3. Jun 26, 2017 at 9:16 AM
    Since it doesn't happen in neutral. Good it be a driveline issue, maybe a drive shaft. Have you recently made any changes.
  4. Jun 26, 2017 at 9:22 AM
    Apacker89
    Andrew
    Besides the tune up I mentioned nothing has been done to the jeep besides breaks a few months ago.
  5. Jun 26, 2017 at 9:16 PM
    Since you mentioned the brakes in post #2, are the rotors warped? calipers frozen? brake pads? lugs tightened?
  6. Jun 26, 2017 at 9:20 PM
    Apacker89
    Andrew
    I've gone through them all seem to be fine. I went over them all the other day and nothing was out of place. Could a bad u joint cause a vibration like this? I'm not too familiar with this. I try to fix what I can,but I have never dealt with u joints before.
  7. Jun 27, 2017 at 8:41 PM
    do you only feel it in acceleration? When did this start? How much lift do you have?
  8. Jun 27, 2017 at 8:45 PM
    Apacker89
    Andrew
    It is stock, so no lift, and durring acceleration only(above 30mph).
  9. Jun 27, 2017 at 9:32 PM
    It could be that your drive shafts need new U-joints. I'm just shooting in the wind here. My idea of a failed U-joint is a broken one. They are $10 each for the non-greaseable sealed ones at Oreilly's. A Jeep weed out and only takes an hour or so to change out.
  10. Jul 7, 2017 at 10:30 AM
    Smoke Doc
    Smoke Doc New Member
    My 91 started a bad shack at 40mph turned out lost a balancing wait off one of the front rims.
  11. Jul 10, 2017 at 9:37 PM
    I like the way you are thinking. A bad shake very well could be a weight or a tire that has belts broken and separating on the verge of a blow out. Check the obvious first the tires.
