Need Help with Decision to Replace Transmission
Discussion in 'Wrangler TJ (1996-2006)' started by RuBiCon03, Nov 30, 2022.
  1. Nov 30, 2022 at 10:23 AM
    RuBiCon03
    RuBiCon03 [OP] New Member
    Brian
    2003 Jeep Wrangler Rubicon
    Sway Bar Disconnects Powder-Coated Wheels
    My gear box has been sticky for several months. One mechanic told me it required a new master/slave cylinder replacement to fix it.
    A different mechanic told me that the 'doghouse' rings inside the transmission are worn and that is the issue causing the problem. He mentioned that the transmission either needs to be rebuilt or that I need a new transmission.
    I'm at a loss for what to do. Go to a third mechanic and get a third opinion? Deal with the issue? Hard to stomach paying $1,500-$3,000 for this.
  2. Dec 2, 2022 at 10:39 AM
    Piratesailor
    Piratesailor Active Member
    Texas
    1993 YJ 4.0
    Assume it’s manual. On mine, it’s the synchro that is going bad. Will probably buy a rebuild. AX15 is $1k. Look into a rebuild. And probably go to a transmission specialist.
    Justanotherjeeper likes this.
  3. Jan 5, 2023 at 2:19 AM
    RuBiCon03
    Brian
    Piratesailor, thank you for the reply and very sorry for such a late response. It’s bad ‘doghouse rings’ inside the tranny apparently. It’s definitely a rebuild or aftermarket/refurbished. They are quoting me $1,500 for the part and another $1k for the labor. They also suggested replacing the clutch while I’m in there. I love my Jeep, but I’m ready to scrap it as it’s just too expensive to fix. Especially with 182k miles. Hard to do, but open to help/suggestions. Indeed it’s a manual tranny.
  4. Jul 14, 2023 at 12:53 PM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    I'm not familiar with the TJ floor, but on a JK you can pull the shift tower without removing the transmission. NV3550 transmission?
