Need help with wheel offset
Discussion in 'Wrangler JK (2007-2017)' started by 17Sahara, Feb 27, 2017.
  1. Feb 27, 2017 at 3:55 AM
    17Sahara
    17Sahara [OP] Member
    Will a 18x9 with +18mm offset fit on my 2017 wrangler Sahara unlimited at stock height without any rubbing issues?
    Do I need a level kit or lift for these to fit?
    If not what offset do I need to go with to fit at stock height?
    Any information will be greatly appreciated. Thank you
  2. Feb 27, 2017 at 7:34 AM
    welcome! I don't know much about wheels, but hopefully someone will be able to help.
  3. Feb 27, 2017 at 1:04 PM
    I believe that +18mm offset on an 18x9in wheel is too much back space at 5.71"
    0mm offset = 5"
    I believe that you really don't want anymore than 4.75" backspace which is close to -8mm offset, but Richard, I believe will have more info on backspacing on a JK.
    The size of the rim does not make a difference on the amount of lift you need. Bigger tires may require more lift.
  4. Feb 27, 2017 at 1:13 PM
    17Sahara
    Ok so 0 offset is my choice I would need. I using a 255/70/18 tire.
  5. Feb 27, 2017 at 5:57 PM
    Is 255/70/18 the tire you have on your jeep now and you are wanting custom wheels for it?
  6. Feb 27, 2017 at 6:07 PM
    4.75" of backspace is the most that you want. For an 18x9" wheel that equates to about a -8mm offset which I have never seen. A -12mm offset is roughly 4.5" of backspace and is what I would run if I were you. In the future if you wanted to go up to bigger tires the -12mm offset would allow you to do that without any tire rubbing on your control arms.
    Bob and chris4x4 like this.
  7. Feb 28, 2017 at 5:57 AM
    17Sahara
    Yes 255/70/18 is the tire I have now and want aftermarket wheels for them.
    Ok I'll will be looking for a 18x9 wheel with a -12mm offset.
    Thank you for the help and info
  8. Feb 28, 2017 at 4:45 PM
    17Sahara
    Ok this was just told to me. Why is this the opposite from I've been told? I really need to be absolutely sure before I drop $1k or more on wheels.
    Manufacturer recommends a +15 to +25 offset for your vehicle and this would allow you to run the stock tire size of 255/70R18.
  9. Feb 28, 2017 at 6:00 PM
    Backspace is more important than offset. Maximum or minimum backspace measurement needed to fit a wheel and tire stays the same no matter how wide or what brand you choose. The Offset of a wheel will change based on different wheel sizes, and some manufacturers can differ in there backspace for the same offset (go figure). I just spoke to my buddy a manager at discount tire. To maintain a factory stance with 18x9 in wheels keeping factory tires you don't want to go more than 0mm offset. That is 5in of backspace. If you get an 18x9 in wheel and decide as most of us do that you want to run a 33 in tire then you will have to either buy new wheels to fit the tire, or buy spacers to fit them. When researching wheels and sizes you will notice that all manufacturers offer of backspace and offset measurements.
    The +15 to +25 offset is true for a narrower wheel like the 18x8.5. Offset is measured in mm and is based on the center of the wheel.
    Here is backspace in relation to the offset
    Here is how to measure backspace.
    The straight edge must be on the wheel not the tire. Take your wheel off and lay it face down on the ground. Take your backspace measurement. this is the max backspace that I would run. If you run a wider tire in the future you will need to accommodate this wider tire by running less backspace. I hope this makes things a little more clear.
  10. Feb 28, 2017 at 6:05 PM
    Here is a picture of my JKU 4in lift on 37x12.50x17 tires with 17x9in wheels (same width as a 18x9in wheel). I have -12mm offset and 4.5in of backspace.
    10520639_10205454008248239_3911457131801919965_n.jpg 1513820_10205454008008233_364809017816106242_n.jpg 20160612_154947.jpg
    Mike Adkins, Billy1234 and JKBob 25 like this.
  11. Feb 28, 2017 at 8:00 PM
    17Sahara
    Ok choosing a 18x9 with 255/70 tire if I go with a -12 offset they will fit with no issue. Just stick out of the fenders? 0 offset will keep factory stance inside the fender. Is that correct? I really appreciate all your help and time you are giving me. I am truly greatful. Thank you
  12. Mar 1, 2017 at 6:09 AM
    Sounds like you have the idea. As for actually sticking out of the fenders, I'm not sure about that. It is a half inch difference between 0 and -12mm offset. You may be still completely covered with your factory tires. Personally I like a little stickout. Looks tuff.
  13. Mar 12, 2018 at 5:29 PM
    Plowking109
    Plowking109 New Member
    Jason
    Chicago
    2012 Sahara Unlimited Altitude
    Flowmaster Force II Axel Back Exhaust, Dual Tips
    So, if I am ordering 18X8.5 rims and plan on sticking with the stock tire size of 255/70R18, will there be any problems? OFFGRIDs post makes me believe I should be ok but I am so confused with all the offset talk. Will my tires fit fine or will they stick out. I thought I understood the explanation on Tirerack.com that negative numbers equate to tires sticking out, positive numbers keep it tucked under the fenders. I would have liked a little sticking out but the rims I have been looking at do not offer them. If I am even understanding it correctly. I appreciate any help provided. Thanks.
  14. Mar 12, 2018 at 5:57 PM
    Welcome to the site! Without knowing the offset its hard to guess how much they will stick out.
  15. Mar 12, 2018 at 6:14 PM
    Blue Baby Sound
    Jeff
    Build threads in sig
    Backspace will be the preferred measurement for this conversation, it remains constant no matter the wheel width. Offset will change depending on wheel width.
    The factory wheel is 6.25" Backspace (BS), any stock size tire will fit without rubbing.
    Once you go with a larger tire then you need to start adjusting the amount of BS.
    33" tire around 5" BS
    35" tire around 4.5" BS
    37" tire around 3.5" BS
    BS can be added with aftermarket wheels or by adding spacers. If adding spacers go with a quality brand, don't cheap out.
    Tire width also plays into the equation, but the above measurements will work with most of the popular sizes.
    Good luck and WELCOME!!
  16. Mar 12, 2018 at 6:43 PM
    Plowking109
    Jason
    Chicago
    OMG, I was so geeked out to sign up and post I forgot to list the wheels have a 15 offset as listed from the web site for the size wheel I mentioned. Thanks again!
  17. Mar 12, 2018 at 6:52 PM
    Welcome! You just received excellent information to order the right wheels. Be sure to post up some pics of that Altitude and new wheels
  18. Mar 12, 2018 at 6:55 PM
    Blue Baby Sound
    Jeff
    That comes out to 5.34" BS, you can use an online calc like this one: https://www.customwheeloffset.com/tire-wheel-backspacing-offset-calculators
    So yes, you're good with those wheels so long as the bore and bolt pattern are in spec. It will stick out about 1" more than your stock tires/wheels.
  19. Mar 12, 2018 at 7:03 PM
    BTW.
    Welcome to the forum @17Sahara and @Plowking109.
    Some awesome advice posted up for you guys. Would love to see some Jeep porn pics when your done with what you decide to do.
    Blue Baby Sound and chris4x4 like this.
