New heart for TJ
Discussion in 'General Jeep Discussion' started by 32peapicker1, Jan 18, 2020.
  1. Jan 18, 2020 at 9:05 AM
    32peapicker1
    32peapicker1 [OP] Member
    97 xj
    Heavy mods
    Good day all, have a question regarding an engine and tranny swap. I have a 97 tj 4 cylinder with ax5 and 231 t case. Also have a 93 zj straight 6 auto and 241 t case. Going to put 6 and auto in the tj. To go ahead and answer the obvious, I am an experienced fabricator, and a gear head. The question I have is what hiccups might I run into with electronics and wiring, gauge cluster and the like. Thank you in advance. And I used to be a toyota guy, my wife brought me over to the dark side.
    aggrex and Billy1234 like this.
  2. Jan 18, 2020 at 9:11 AM
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    Welcome to the family from ny sounds like your ganna have a fun time with the swap. I'm not much help hopfully someone else will chim in soon like @Prerunner1982 or @Awrench, @aggrex
  3. Jan 18, 2020 at 9:20 AM
    32peapicker1
    97 xj
    Heavy mods
    Thank you for the welcome and the bump, sorry for the short and sweet post. I have looked at a bunch of other swap threads, didnt find the particulars of the electrical side of things.
    Billy1234 likes this.
  4. Jan 18, 2020 at 9:51 AM
    Welcome to the site!
  5. Jan 18, 2020 at 10:11 AM
    Welcome @32peapicker1 ...interesting project. Fabricator+gearhead are great skills that might be needed for that conversion for example the motor mounts are a typical issue for the novice. Check out Novak-adapt.com for info on similar conversions. Best to obtain the ECU, harness, etc in addition to the motor, trans, etc from the donor vehicle.
  6. Jan 18, 2020 at 10:17 AM
    32peapicker1
    97 xj
    Heavy mods
    Thank you, being new to keeps I don't know where the info is. Will give Novak a look. And I have the whole zj so parts will not be an issue, well except for drive shafts.
  7. Jan 18, 2020 at 10:53 AM
    When it's time for drive shafts the jeep world is ready with Tom Woods or Adams who will custom build them for your application
  8. Jan 18, 2020 at 11:35 AM
    32peapicker1
    97 xj
    Heavy mods
    Thank you, yes, I found addams while building my xj, very good company.
  9. Jan 18, 2020 at 12:58 PM
    CZJ7
    CZJ7 Jeep—rotating the earth since 1941
    Robin
    Farmington, NM
    1980 CJ7
    Very similar to what I will be doing with my old CJ.....the same exact engine/trans. Keep the PCMs together with their respective engines/trans...the 4 cyl. Brain will not run the 4.0.
    One huge advantage is the OBD I system as they are much simpler than the later OBD II, and work just as well. Also, as I understand it, the engine and trans have separate control modules, simplifying hookup. I’m not sure if the body electronics will need to talk to the PCMs, but I don’t think so....I haven’t run across anything that says it will matter, especially to the power train.
    Another bonus of the ‘95 and older ZJs is they have the most potent 4.0 due to the cylinder head—yours should have “7120” cast into it at the mating surface, driver’s side, dead center between #3 and #4 cylinders. It’s a the best head of the three iterations put on the 4.0.
  10. Jan 19, 2020 at 4:27 PM
    32peapicker1
    97 xj
    Heavy mods
    Picking up the zj this week, I will definitely share which cylinder head it has, thank you for the information!
  11. Jan 20, 2020 at 6:07 AM
    The potential problem I see is trying to mate a OBD1 engine management system into an OBD2 vehicle, mainly the interior.
    But..... I have never done a 4 Cylinder OBD2 to 6 cylinder OBD1 swap so I can't speak from experience... it doesn't sound fun.
    I have swapped an OBD2 engine into an OBD1 vehicle but it was a 6 cylinder for a 6 cylinder so it didn't really require anything other than swapping the sensors over.
    I am planning on swapping the HVAC box from my 97 XJ (OBD2) to my 93 (OBD1) non A/C XJ and it's going to be a "fun" project.
  12. Jan 20, 2020 at 6:47 PM
    32peapicker1
    97 xj
    Heavy mods
    Worst case scenario is having to change out the gauge cluster and body harness I think, i will keep this thread updated as to what i run into.
    Prerunner1982 likes this.
