New old hard top
Discussion in 'Wrangler TJ (1996-2006)' started by lbr3570, Nov 28, 2019.
  1. Nov 28, 2019 at 5:46 PM
    lbr3570
    lbr3570 [OP] Member
    Big Red '04 TJ Sport
    Just put a hard top on my '04 TJ for the first time...decent craigs list find. The drivers side latch was a little loose- tightened it up ok. Inside is nice and quiet until I hit about 40mph...then it sounds very breezy from the front. There is no air leaking in from the front header area- just loud (not as loud as the soft top, but more than I thought). Is this normal? I guess I was expecting a more quiet ride...?
  2. Nov 28, 2019 at 6:43 PM
    Welcome @lbr3570 ....assuming its the correct hard top for your TJ, the hard top is durable and strong but is not insulated against wind noise. Aftermarket headliners may help to reduce or lower some of that wind noise.
    JKBob 25, chris4x4 and lbr3570[OP] like this.
  3. Nov 29, 2019 at 4:03 AM
    lbr3570
    lbr3570 [OP] Member
    @aggrex thanks I didn't even know this was a thing. It really feels like it's coming from the front top of the windshield- although theres's no wind coming in-I need some rain (or a quick run through a wash) to make sure there's no leak from there...then I'll have a different question.
  4. Nov 29, 2019 at 8:00 AM
    Have someone use a garden hose to simulate a rain storm and not a monsoon and look for any leaks. Home centers like HD/Lowes have foam trim that can help if needed. Since the hard top is used clean+condition any rubber seals and make sure all of them are present and not damaged. My 2016 JK might get a few drops on the rubber mat during a big violent storm but as long as the carpet remains dry its all good.
  5. Nov 29, 2019 at 9:01 AM
    Welcome to the site! Can we see some pictures of it?
    lbr3570[OP] likes this.
  6. Dec 2, 2019 at 12:23 PM
    lbr3570
    lbr3570 [OP] Member
    @chris4x4 thanks! So now that we’ve had rain... I’ve got some water coming in. Top Front corner of passenger door- I kinda think the door molding is old. What kind of molding can I use to replace it?
    Also- Where the tailgate meets the window- there’s a gap- more molding or weather strip needed... (5th pic ) recommendations?
    And... the back window on the top and bottom ledge- is there supposed to be molding there? Sorry never was in a hard top before! ( first 2 pics)
    And just some other fun pics.
  7. Dec 2, 2019 at 12:25 PM
    lbr3570
    lbr3570 [OP] Member
    My favorite pic ♥️
    chris4x4, aggrex and Billy1234 like this.
  8. Dec 2, 2019 at 12:33 PM
    Billy1234
    Billy1234 Well-Known Member
    William
    1997 XJ 2 door
    None yet
    Shes a beauty!
    JKBob 25 and lbr3570[QUOTED][OP] like this.
  9. Dec 2, 2019 at 2:27 PM
    lbr3570
    lbr3570 [OP] Member
    @Billy1234 she'll be better when I can stop the leaks!:angrygirl:
    JKBob 25 and Billy1234 like this.
  10. Dec 2, 2019 at 2:30 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Trust me I'm going threw the same with my 97 DJ and coolant issues to..... :frusty:
  11. Dec 2, 2019 at 8:55 PM
    Check out this website first: https://www.quadratec.com/vehicle/1997-2006-wrangler-tj/body-and-frame/seals
  12. Dec 3, 2019 at 5:12 AM
    Not sure if you know or not but you are missing a piece of weather strip around the back window. Where you asking what’s missing???
  13. Dec 3, 2019 at 6:12 AM
    lbr3570
    lbr3570 [OP] Member
    @LYFZGOOD the second pic shows the back window... there is supposed to be weatherstripping there??? That space Around where the window shuts...I did not know this! Got a pic of what it’s supposed to look like?
  14. Dec 3, 2019 at 6:40 AM
    lbr3570
    lbr3570 [OP] Member
    @LYFZGOOD so in that groove all around the whole back window there’s supposed to be weather stripping.
  15. Dec 3, 2019 at 8:26 PM
    Yes. Google hard top weatherstripping
  16. Dec 4, 2019 at 4:03 AM
    lbr3570
    lbr3570 [OP] Member
    WOW. Ok found it. For the bottom glass of the window...do I have to replace the entire plastic strip with the molding or can I just do the molding... hmmm wish the craigslist guy gave me a heads up :mad:
  17. Dec 6, 2019 at 4:01 PM
    Molding should be fine no need to replace the plastic I don’t think
  18. Dec 9, 2019 at 4:50 AM
    lbr3570
    lbr3570 [OP] Member
    Ok- so I did get some molding for the tailgate-seems to stop the leaking. the craigslist guy said he has the top of the window molding and was going to install it...so he is supposed to be sending it to me. Hmmm. AND I put extra molding around the window area and discovered today that there is a small crack in the actual TOP... NOW WHAT??? Talk to me about fiberglass patch??? Is this a thing? I texted the guy and asked if I can trade it in for one that doesn't leak...:argue:
  19. Dec 9, 2019 at 4:58 AM
    lbr3570
    lbr3570 [OP] Member
    Ok someone just mentioned “flex tape” or that waterproof spray... anyone have any comments on this? ☹️
  20. Dec 9, 2019 at 5:52 AM
    Is the crack that bad ? You can see water coming in Through the crack?
