No brake lights in 2005 Grand Cherokee, need help
Discussion in 'Grand Cherokee' started by jws123, Jul 30, 2019.
  1. Jul 30, 2019 at 9:55 AM
    jws123
    jws123 [OP] New Member
    I am new here so not sure if this is correct spot.. any ways
    2005 jeep grand cherokee limited 5.7 this jeep has been a pain in my *** electrically since i got it lol i just got it back on the road finally and i noticed!!! i have no brake lights. i changed the bulbs then changed the strips in both tail lights as they where rusted also changed stop switch on petal wasted $90 so far blinkers work running lights work checked all fuses then after reading a few diff threads i checked for power at fuse 27 under the hood it does have power
    Also i should note i changed the main fuse box inside the jeep not long ago due to the sun roof backing up and getting it wet.
  2. Jul 30, 2019 at 11:14 AM
    jws123
    where is the relay for brake lights?
  3. Jul 30, 2019 at 8:11 PM
    Hey @jws123 . Yes. There should be a relay in the line some where. And most likely. A fuseable link. After every thing you changed and swapped out. It sounds electrical. :cool:.
    I'm sorry dude. I couldnt help myself. Electrical issues are not my strong suit. Honestly...don't really have one. Lolllllo.
    Hope another member helps find a fix. I'm :popcorn:.
  4. May 25, 2020 at 10:26 PM
    Satanic Mechanic
    Satanic Mechanic New Member
    Betsy 99 Jeep Grand Cherokee
    Intake airtemp sensor relocation 28 MPG highway
    So I have had a similar experience with my 99 grand the problem turned out to be the metal connectors in the brake light housing had became loose
