No spark at coil
Discussion in 'Cherokee' started by Bobwrs22, Oct 17, 2018.
  1. Oct 17, 2018 at 10:58 AM
    Bobwrs22
    Bobwrs22 [OP] Member
    89 Cherokee Laredo
    I was driving and I broke the u-joint at the rear diff the Jeep died and now won't start and ideas why
  2. Oct 17, 2018 at 11:15 AM
    Welcome! Two separate issues that might not be related unless you were jeeping over some obstacle with some passion. Water crossing?
  3. Oct 17, 2018 at 11:20 AM
    Bobwrs22
    89 Cherokee Laredo
    Nope driving on black top maybe 20 mph but what gets me is it started giving me this problem when it broke I didn't think the two were related but can't rule anything out
  4. Oct 17, 2018 at 11:27 AM
    Did the driveshaft going flopping around? If so could it have caught any wires under the Jeep such as the fuel pump?
    If not, the Crank Position Sensor (CPS) is a common failure that will cause a no spark symptom.
  5. Oct 17, 2018 at 11:33 AM
    Bobwrs22
    89 Cherokee Laredo
    Fixing to buy and install now will update
  6. Oct 17, 2018 at 11:37 AM
    You might test it first.
    TESTING PROCECURE for 1987 – 1990 4.0 L engines
    Test # 1 - Get a volt/ohm meter and set it to read 0 - 500 ohms. Unplug the CPS and measure across the CPS connector's A & B leads. Your meter should show a CPS resistance of between 125 - 275 ohms. If the CPS is out of that range by much, replace it.
    Test # 2 - You will need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. (The engine can't fire up without the CPS connected but watch for moving parts just the same!) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5vac, replace it.
  7. Oct 17, 2018 at 12:21 PM
    did you check SPARK, FUEL PRESSURE, fuses. WHY do we pick the CKP as a problem part? A PIA to change....
    I am not sure what model, engine etc is there 12v at injectors? at coil?.
    sorry confused - is there 12v at coil? is coil being pulsed?
  8. Oct 18, 2018 at 12:08 PM
    Bobwrs22
    89 Cherokee Laredo
    Crank position sensor was the problem new question I can run 85 + in 4th gear but can't hold 75 in 5th any ideas
  9. Oct 18, 2018 at 12:10 PM
    Bobwrs22
    89 Cherokee Laredo
    Awrench it's a 89 Cherokee Laredo with a 4.0 inline 6 4x4
  10. Oct 18, 2018 at 12:16 PM
    Running any oversized tires?
  11. Oct 18, 2018 at 12:19 PM
    Bobwrs22
    89 Cherokee Laredo
    31s a little wide nothing crazy
