No turn signal
Discussion in 'Cherokee' started by oldman, Sep 11, 2018.
  1. Sep 11, 2018 at 2:55 PM
    oldman
    oldman [OP] Member
    Harry
    98 grand cherokee
    I need help, I have a 98 Grand Cherokee Laredo and the turn signals started to flash fast on the left about a week later the flashers stopped working, I have changed the flasher module and the switch on the column , I allso went though and checked all the ground wires i could find and I have fire to two of the plugins in the flasher plugin on the fuse block but no fire to the turn signal or the indecater lights on the dash I'm lost I have changes the bulbs and the blub socketts too.
  2. Sep 11, 2018 at 3:39 PM
    RubiconFreedom
    Nor-East Uni-Stat
    You've went though the common most check list, but one thing you neglected to mention was, did you or did you not simply disconnect and clean the battery terminals..
  3. Sep 11, 2018 at 6:36 PM
    oldman
    oldman [OP] Member
    Harry
    98 grand cherokee
    I replaced the old ones with new brass ones, I'm thinking when I pulled the old relay I may have done something to the socket in the fuse box
  4. Sep 12, 2018 at 7:29 AM
    a test light and diagram should help
    do you have a trailer connector - they are often a problem.
  5. Sep 12, 2018 at 8:54 AM
    oldman
    oldman [OP] Member
    Harry
    98 grand cherokee
    ya, I've been going through it with a test light and I unhooked the trailer lights. I noticed that for over a year I had a check engine light on after I replaced the catalytic converter now the lights out and no codes show could that have something to do with it or just a coincidence i really appreciate the help
  6. Sep 14, 2018 at 7:53 AM
    oldman
    oldman [OP] Member
    Harry
    98 grand cherokee
    well this thing is driving me nut's, I checked the fuse box and I have fire to the hot side of the module and the switch side, I thought maybe the ground was broken, so I made a jumper and that didn't work I was hoping that was it
