NSS on 2008 Jeep Wrangler
Discussion in 'Wrangler JK (2007-2017)' started by thehorse92, Mar 31, 2019.
  1. Mar 31, 2019 at 9:23 AM
    thehorse92
    thehorse92 [OP] New Member
    John
    2008 Jeep Wrangler
    Anyone know where it’s located? It’s an automatic
  2. Mar 31, 2019 at 10:57 AM
    the TRS signals PCM the gear selection.
    You might want to describe your issue, list all codes your scanner is displaying.
  3. Mar 31, 2019 at 11:36 AM
    thehorse92
    John
    2008 Jeep Wrangler
    Jeep wouldnt start unless I jiggled the gear shift or put in neutral. The problem was on again off again. Now it won’t start even after putting in neutral. Battery good. Seems like the neutral safety switch needs replaced but I can’t find the neutral safety switch on the jeep
  4. Mar 31, 2019 at 2:22 PM
    Welcome to the site!
    thehorse92[OP] likes this.
  5. Apr 2, 2019 at 9:02 AM
    Mine does that on my LJ have to pull back on shifter slightly to make it start linkage adjustment I imagine oh yeah and welcome from Texas
  6. Apr 2, 2019 at 8:05 PM
    Welcome from NJ. @thehorse92 .
    Dine and dasher? Post up your fix. Might help another member in the future.
  7. Apr 3, 2019 at 2:53 AM
    thehorse92
    John
    2008 Jeep Wrangler
    Ended up going to the shop. More once they diagnose
  8. Apr 11, 2019 at 7:07 AM
    thehorse92
    John
    2008 Jeep Wrangler
    The shop replaced the wiring harness. Worked for a day, now starting intermittently
  9. Apr 11, 2019 at 3:12 PM
    If it was the NSS I hope they have an explanation for replacing the wire harness. The NSS for the Jeep are usually on the transmission with linkages and a electrical connector
