OEM LED Headlights.
Discussion in 'Wrangler JK (2007-2017)' started by JustBabs, Dec 6, 2020.
  1. Dec 6, 2020 at 12:00 PM
    JustBabs
    JustBabs [OP] Member
    2016 White Sahara JKU
    I have a 2016 JK and the stock headlights suck. I found a set of OEM LED Headlights on eBay. The ad describes them as 2007-2018. I am leery because I thought the LED's became an option in 2017? Would they fit my JK? I've seen aftermarket lights that say they would require a bracket for 2017 models.
  2. Dec 12, 2020 at 8:30 AM
    JustBabs[OP] and aggrex like this.
  3. Dec 13, 2020 at 5:54 AM
    JustBabs
    Thanks for the link. I've been reading reviews and the one thing that keeps popping up is the bright spot. Some say it's to focused, and like driving in a tunnel, others says it's off center and can't be adjusted. A few reviewers complained about flickering, even though an anti flicker harness comes with them. Have you had any of those issues?
  4. Dec 13, 2020 at 6:10 AM
    gibbster
    gibbster Active Member
    Daryl
    Carbon county, Mt
    2016 black JK Wrangler Sport Unlimited
    Rancho 2” lift? Yokohama geolander 295/70r17 MT tires.
    I believe those are what was put in the jeep
    I purchased and they do flicker some. Probably going to change them.
  5. Dec 13, 2020 at 7:18 AM
    I never had any issues. The Euro Spec jeeps have an adjuster screw that allows for side to side adjustment. I ordered a couple of those, and it allowed perfect adjustment.
    Mopar 55078114AA Headlamp Adjustment Screw 07-16 Jeep Wrangler & Wrangler Unlimited JK | Quadratec
    These guys show how they are installed, around the 5:20 mark:
    Jeep JK Headlights Adjustment + Mopar Euro Headlamp Adjustment Screw | Northridge4x4 - YouTube
  6. Dec 13, 2020 at 8:54 AM
    There has been changes and improvements made on the latest QT headlights. Depending upon where you live the new ones are heated and might be made by JW. Quadratec is a reputable Jeep parts vender unlike nearly anything found on eBay especially used headlights which should be buyer beware.
    JustBabs[QUOTED][OP] likes this.
  7. Dec 13, 2020 at 9:34 AM
    JustBabs
    I live in CNY. Heated may be a viable option. I'm looking at these for the heated lens - https://www.quadratec.com/p/quadratec/heated-led-projector-beam-headlamps-jeep-wrangler-jk
    Unfortunately, my year JK didn't come with DRL's. These have them integrated for those models that did have DRL. Bummer, I wish there was a way to activate them.
