Oil light
Discussion in 'Liberty' started by Natalie, Dec 17, 2017.
  1. Dec 17, 2017 at 6:16 PM
    Natalie
    Natalie [OP] Member
    Natalie
    2002 Liberty limited ed
    Oil light in my Liberty comes on than goes out. Checked her oil it's fine any ideas.
    Thanks Nat
  2. Dec 17, 2017 at 6:24 PM
    Welcome to the forum Natalie. Possibly just running threw a diagnostic check. Are the other (edit) lights coming on also? Or is it just that one light? When is it happening? At start up, or just at random times? Could also be a loose connection.
    Again. Welcome.
    Natalie[OP] and Bob like this.
  3. Dec 17, 2017 at 6:29 PM
    Welcome! How do you define checked? Some basic things to consider as the oil light is an "idiot light": oil levels are best checked cold, correct oil viscosity?, beyond oil change interval? oil pressure checked with gauges?
    Natalie[OP] and chris4x4 like this.
  4. Dec 17, 2017 at 6:32 PM
    Didn't mean to offend anyone. Just a term I've heard used for years. Not in any means referring to the owner of the vehicle. To avoid issues. I'll edit that out.
  5. Dec 17, 2017 at 6:33 PM
    Welcome!
    Natalie[OP] likes this.
  6. Dec 17, 2017 at 6:39 PM
    My bad...."dash board warning lights".
    From Wilkipedia: The "idiot light" terminology arises from popular frustration with automakers' use of lights for crucial functions which could previously be monitored by gauges, so a troublesome condition could be detected and corrected early.
  7. Dec 17, 2017 at 8:02 PM
    Yeah....no comment. Whatever.
  8. Dec 18, 2017 at 12:27 AM
    Natalie
    Natalie [OP] Member
    Natalie
  9. Dec 18, 2017 at 12:30 AM
    Natalie
    Natalie [OP] Member
    Natalie
    No other lights come on... when I say check .. I mean pull the dip stick check ... lol .. It comes on randomly when I'm driving... Than goes off ..
  10. Dec 18, 2017 at 12:36 AM
    Natalie
    Natalie [OP] Member
    Natalie
  11. Dec 18, 2017 at 12:45 AM
    Natalie
    Natalie [OP] Member
    Natalie
    I always check my oil when it's cold and she's not been running is that wrong ... Or should I check it after it's been running for a while ... I mean dip stick ...I'm definitely a girl and don't work on her ... But this oil light thing is just starting
  12. Dec 18, 2017 at 1:04 AM
    Natalie
    Natalie [OP] Member
    Natalie
    Sorry I didn't reply ...I get up really early for work
  13. Dec 18, 2017 at 6:27 AM
    Just a thought. On your way home from work, swing by an autoparts store, (autozone, Oreilly's) and ask them to check you jeep codes (DTC or Diagnostic Trouble Codes) You onboard computer will keep a record of them and they will be able to tell you if you have any and what they are.
    The oil light should come on when you are reading a low or no oil pressure. First I would replace the Oil sensor $11 at Oreillys. See if this fixes your problem. The only other thing would be the Oil pump. These don't usually go bad.
    https://www.oreillyauto.com/detail/...h-light/s4188/2610255/2005/jeep/liberty?q=oil
  14. Dec 18, 2017 at 9:10 AM
    Natalie
    Natalie [OP] Member
    Natalie
    Thank you Peter ... Will have them check
