Over heat problems
Discussion in 'Wrangler TJ (1996-2006)' started by Adam39601, Jun 2, 2018.
  1. Jun 2, 2018 at 10:06 AM
    Adam39601
    Adam
    2001 jeep wrangler sport
    Were can I get a larger radiator for my 01 tj
  2. Jun 2, 2018 at 10:40 AM
    What is the problem?
    You could compare your radiator to other options- engines, HD or tow packages, then visit a local radiator shop
    - local will be better for any fitting issues much easier than internet type - shipping costs, TIME waiting, no face to face discussions.
  3. Jun 2, 2018 at 11:06 AM
    Adam39601
    Adam
    It over heats really bad it will redline then go down to around 210 it just fluctuates
  4. Jun 2, 2018 at 11:34 AM
    why do you think its the radiator?
    are you loosing coolant?
    have you changed thermostat?
    any restriction - airflow thru radiator, clogged radiator ?
    I have seen WP's fail ...
  5. Jun 2, 2018 at 1:58 PM
    As was mentioned do the simple things first coolant checks>flush>thermostat>air flow restrictions. Noisy water pump? Radiator old? Sudden problem?
  6. Jun 2, 2018 at 7:03 PM
    Outside the box question. Was a leak stop ever used? That chit will cause more issues than you'll want to deal with.
    OFFGRID and aggrex like this.
  7. Jun 3, 2018 at 5:52 AM
    Agree with bob. If you ever used a stop leak you should replace everything. That stuff cloggs up your system. Fluctuating temp is likely a clogged radiator or old thermostat or both.
