Over heat problems
Discussion in 'Wrangler TJ (1996-2006)' started by Adam39601, Aug 12, 2018.
  1. Aug 12, 2018 at 6:37 PM
    Adam39601
    Adam
    2001 jeep wrangler sport
    Helllllp what is making my radiator over heat when I'm driving in town? I have drained an flushed it out replaced radiator with after maker ome with fan.all works but when I am doing stop an go traffic it will hit 260. Any help in fixing this please do.....thank you
  2. Aug 12, 2018 at 6:48 PM
    Some possibilities: new thermostat and installed correctly? 50:50 coolant? air in the system? fan shroud installed? fan engaging at correct temps?
    Squatchy and JKBob 25 like this.
  3. Aug 13, 2018 at 8:06 AM
    IIRC this is a viscous fan drive and NOT an electric fan - YES on I'm wrong?
    could there be a loss of coolant? gasket, correct radiator cap, hose?
    did you check viscous fan drive?
    you did use a good quality thermostat at correct rating ? never use a lower rated T'stat.
    As mentioned - installed correctly?
    TIP: when installing a thermostat, place an aspirin (you- use your viagra) :) to hold valve open this will greatly help purge the system of air....
    Prerunner1982 likes this.
